Computers & Internet Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer always hang, then i always restart it until it will function normally...whats the common problem for it? so that i can fix it immediately..
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on Nov 22, 2009
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
307499
Points
2315
There a lot of unused files in your PC. Just install the
Tune Up Utilities of 2008. Once installed Click open
Tune Up 1-Click Maintenance. This will erase the unused files in your PC. Furthermore, Also install
Your Uninstaller of 2009. Once installed, Click open,
1 - Click Cleaning to clean your PC further. Both programs will correct your problem.
You can connect to the internet and get the download
one at at time. Just type at the Search engine blank
(Free download of Tune Up Utility of 2008) and Click
the search engine. Once you get to the site, click
at the free download) Once you have the download,
install it in your PC, by clicking it open.. Once installed,. Click open the 1-Click Maintenance at the
desktop. Follow the same procedure with the Your
Uninstaller of 2009 download.
I'm pretty sure, this will speed up your PC and no
more hang up.
Furthermore, always keep your anti virus software
updated, and run the virus scan to keep it on tiptop
condition.
Anonymous
Level 2:
New Friend:
  • Expert 74 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
74
Questions
Helped
16590
Points
196
My laptop was hanged from last one hour how to start of samsang compeny
If I understand correctly; your laptop is hanging( hung in a loop ) and unable to function. I suggest a "Hard Shutdown". This will allow the computer to restart. Press and hold down the laptop's power button for approximately 15 seconds. The laptop should power off then press the power button normally and it will restart. Start up may take longer especially if you are using a Windows Operating System. The Operating System may detect that there was a problem and will attempt to correct. Simply follow the onscreen prompts. Good Luck.
My cg100 camera always freezes is this common.
Seems to be quite normal. The manual says on page 133:
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold the Power button for 6-8 seconds. The device reboots automatically.
If this does not solve the problem, perform a factory data reset. On the Applications screen, tap Settings > Backup and reset > Factory data reset > Reset device > Erase everything.
Jan 09, 2014 • Cameras
How to fix 6120c that always restarts and mp3 music always hangs:
If you encounter hanging or slugging problem,this is when the memory is almost full and can't operate some phone function properly.
Here are some steps to maintain your phone and it's function
1. Erase/Delete unused data such as messages,photo,songs,video,games etc. or you can transfer it to memory card so the phone can operation smoothly.
2.All download files (as what step 1 contains)should be in memory card to avoid phone memory full and phone malfunction.
3.If still this problem occur,"RESET" or "RESTORE" by doing this :
a. go to settings and locate "Res.factory sett."
b. choose restore settings only (data is still intact) or reset all (all data will be erased)and warning message will appear.
a lock code will pop up,enter your security or lock code,the default code is 12345 (if you didn't change it before), or enter your desire code (if you change it before)then proceed.wait until your phone restarts.
I hope this solution will help you. thank you for visiting FixYa.
3helpful
AppHang81 Error-help!
what version of windows are you using? state the version and servicepack. in the intrim, start your computer in safe mode and run some programs. shut down the computer and restart in normal mode.
3answers
My Sansa e250 no longer functions when switched on
what can i do if my sansa e250got problem just wen i turn on thers always say refreshing database...... then he hang... and no i con
My desktop PC Windows XP Pro hangs during resart only
try to use msconfig (on run) to see what programs run on system startup. some of these programs may be a malware that keeps on placing trash on your computer. i would recommend you download the Anti Malwarebytes and run it to remove the suspected malware.
regards.
1helpful
2answers
Pc hanging after turning on
I suspect viral activity. Malware does these type of things. You will need to perform isolation techniques in order to prevent the erroneous apps from running. When in doubt utilize task manager to shut down the pc if it is non-responsive (CTRL-ALT-DEL) gives you the menu. When in extreme doubt, RELOAD OS. Save your extreme data first, of course. I like Webroot software.
Acer Aspire 5580 System always restart after diskcheck
Ok have you been able to do those things because the hard work is over. If you were able to copy those files over then start up your computer we may not need to start from the CD.
If not then we have to get your computer to boot from the CD. Start your down computer and upon startup look for instructions that say "hit this key for system" it goes by quick. For Acer it should be Del or F2 or older models its F1 or Ctlr-alt-delete.
Once in BIOS just arrow over to where it says BOOT option. And with the arrow key change the combination to put your CD ROM at the first slot. Once that is done put your CD in the drive with the four files on it and boot up. Your computer should go into the operating system normally.
After all that let me know how it goes...the only other option is to reload your operating system which means all of the files will be lost....
Grand Canyon Tech
Grand Canyon Tech
