this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
SOURCE: intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris. To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
SOURCE: my miele dishwasher 'incognito' is
check all your drain hoses, S trap orifis, filters, non-return valve and pump impelar is clean and free
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
SOURCE: my miele dishwasher shows intake/drain light
hi, firstly check the filter in the waterproof system where the tap is to make sure it is not blocked. turn off the water and remove the connection with the white box attached this is the waterproof system. remove the black seal and you will see the filter. pull it out with a pair of pliers and clean it.
if this is ok check to see if you have a restrictor on the tap or inside the tap and also make sure water is flowing from the tap prior to reconnecting the waterproof system.
run the unit again and when it is time for the machine to call for water you can manually fill it and see if it works using a saucepan or bucket. if this works ok you may have a stuck waterproof system and probably need to replace this.
Hope this helps
