LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
Posted on Nov 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen on my 4 yr old 42 inch LG plasma keeps
The screen on my 42 inch LG plasma keeps flickering like a strobe light. I have had the cable checked and it isn't that. What is wrong?
Philip Frye
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Nov 22, 2009
Philip Frye
Expert
Level 2:
Sergeant:
Answers
295
Questions
0
Helped
64837
Points
784
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Dec 14, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
5438
Points
26
DANG PLASMAS, THE BULBS DO NOT LAST VERY LONG. HONESTLY, SELL IT AND TRY TO UPGRADE TO LCD. AT 4 YRS OLDS, IT'S ALREADY HAD ITS GO. LCD WILL LAST ATLEAST 27000 VIEWING HOURS.
PLASMAS ARE YESTERDAY, NOT WORTH THE REPAIR SINCE LCDS AND LEDS WILL SOON EXCEED 1080P RESOLUTION.
  • matts3bay Jan 27, 2011
    Plasmas dont have a "bulb" lol only LCD's have "backlights" you know nothing about TV's
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
42inch LG plasma TV
well if you could please give out the model nuumber thank you
I have a 3 yr old 42" LG tv that keeps turning off
Please check your capacitors for malfunction. Replace them if needed.
Regards
2answers
No Picture on a 4 yr old TV
I would take it to a repair shop, but it sounds like somewhere in the power board.
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Plasma
if your tv is on warranty take it back to best buy for a replacement.good luck
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
