Press and hold Power and + at the same time.
Go to http://www.manualnguide.com/dl/4354/ for more information.
SOURCE: Import *.gdb route file in Garmin Zumo 550
Import to pc or to garmin device? There is some info in the manual, however you will need an SD card to work with triplogs.
SOURCE: GARMIN WILL NOT TURN OFF
I have the same problem. Seems to happen when I get a photobox warning in a tunnel an after that loose satelite connection in the tunnel. This has happened two times at the same place, The only solution I`ve found so far is to take out the battery and start again. Hopfully there will come a software update for this soon!
SOURCE: garmin zumo 550 bluetooth pairnig problem
The Bluetooht of my zumo 550 can not be switcht on, what ever i do.
The first time it works perfect and it was pairing with my phone afther that it stopt working
SOURCE: Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
SOURCE: Zumo 550 randomly shuts down, sometimes won't power up again.
Try, with gps off, putting it in the bike or car craddle, having whichever running (powered up), press the gps power button and the + button at the same time for like 15 seconds.
May have to do it more than once
