Download the converter after you run the link below ....Put check next to converter/firmware update/Manual
download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(
http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0
usb the back of the
computer is best (the
motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Set sansa to recovery mode, Start the updater plug the sansa into the computer, unplug when told sansa, should restart (Lock sansa press and hold rec and menu until recovery begins)
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Go to my
computer click on folder scroll to sansa and open the
media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
