I had a paper jam, cleared the paper, but now I have the error code "unable to print 30". Does anyone know how to resolve this? Brother MFC-465CN
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
Please follow the instructions listed below to correct this problem:
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Also this might be handy for you.
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote.
All The Best: Pineworks
