Question about Canon FS200 Flash Media Camcorder
Where is the serial number on my camcorder FS200
Where is the serial number on my camcorder FS 200
Posted by harrybraun on
Anonymous
It's listed on the Canon warranty card that came with it. Hope that helps.
Posted on Dec 26, 2009
  • sweetbamabrn Dec 02, 2010
    I called Canon because I could not figure out what it was. If you look on the bottom of the camers on the battery door there is a sticker with some letters and numbers. It is the first 12 numbers that is listed on the first 3 rows. No letters at all.
kryzzle_cata
    New Friend:
Get your SD CARD from the camera and turn up something that makes your card locked! its just like a little on and off switcher in the side part of your SD CARD ....hope it can help
Posted on Feb 18, 2012
I took a movie clip with canon legria fs 200. when I copied the file to my pc it only had sound and no vision any ideas?
Update windows there is a video codec that needs to be updated.
CHeers,
EMbroidery Services
San Diego, CA
Sep 25, 2014 | Canon LEGRIA FS200 Flash Media Camcorder
What is the serial number of model number DCR-SR68
The serial number is on the bottom of the camcorder.If you simply want to install the software for a camcorder, you can tell the installation program the model and serial number of any camcorder from the same manufacturer.
Apr 13, 2012 | Canon FS200 Flash Media Camcorder
What are the serial numbers of the faulty Beko fridge freezers that is a on going problem with the defrost timers.
CA 5411 FFS/FFW/FFX
CA 7014 FFX
CA 7015 FFW/FFS/FFX
CDA 539 FS/FW/FX
CDA 543 FS/FW/FX
CDA 645 FW
CDA 647 FS/FW
CDA 648 FS/FW
CDA 653 FS/FW/FX
CDA 659 FS
CDA 751 FS/FX
CDA 752 FS/FW/FX
CS 460 FF/FFS/FFW/FFSD
CS 461 FFW/FFS
CSA 4706 FFX
CSB 4606 FFSD/FFS/FFW
Hope this helps.
Jul 08, 2011 | Beko Refrigerators
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
Where will i find the serial number on my Legria FS 19 camcorder?
In the battery / memory card compartment, or on a little sticker on the bottom of the camera.
Oct 03, 2010 | Canon Cameras
I am looking for the serial number for the Canon Legria FS20 camcorder. Where would I find it?
The serial number is located on the top surface of the battery compartment cover.
Refer to:
http://gdlp01.c-wss.com/gds/7/0300001917/01/fs20-21-22-200-nim-en.pdf
Go to Page 14.
Thanks for using Fixya.
Please take a moment to rate this solution. Thanks!
Jul 20, 2010 | Canon Legria FS20 Flash Media Camcorder
Canon fs 10 serial number for image mixer
There is a sticker on the battery cover, with a the serial number. It's listed as four numbers, in three rows...
xxxx
xxxx
xxxx
Enter into the software as xxxx xxxx xxxx -- worked for me.
Jan 26, 2010 | Canon FS100 Flash Media Camcorder
How can i see the serial number or how do i reach it cause i cant
press manu button then go to service then press right errow key goto status page press double enter it will print around 5 or 6 page in second page in down you can find the serial number or else see the back side of the printer it should stikared.............
Nov 05, 2009 | Kyocera FS-2000D Laser Printer
I have a canon fs 200. How do you delete information from memory
use a memory stick reader & delete the files/info in your computer
Jul 25, 2009 | Canon FS100 Flash Media Camcorder
How to copy videos from canon fs100 to pc
THE SERIAL NUMBER OF MY CANNON FS 100 IS NOT ACCEPTED
Jul 02, 2009 | Canon FS100 Flash Media Camcorder
Canon FS200  Flash Media Camcorder Logo
5,054 people viewed this question
Top Canon Video Cameras Experts
Harrie
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
