Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs are loose where the hose connects. Any ideas?
Posted by johnbianco on
Anonymous
    New Friend:
  • 5 Answers
Other option is that on the hose end of the electrical connection, you can use an awl on the electrical connections to bend them in slightly so they make good contact when they are automatically plugged in when you connect the wands. HOWEVER, ONLY DO THIS WITH THE VACUUM UNPLUGGED, I RECOMMEND REMOVING THE HOSE FROM THE CANISTER TO BE CERTAIN THERE IS NO ELECTRIC CURRENT IN THE HOSE BEFORE USING ANY METAL TOOLS TO REPAIR.
Posted on Nov 23, 2009
Anonymous
  • 430 Answers
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Posted on Nov 22, 2009
How do I get hand held vacumn to work without attaching it?
Sounds like the dirt container if full and overflowing.
Aug 31, 2014 • Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
I am having trouble with my back wheels on my Electrolux 2100 canister vacuum. They will spin when the vac is upside down, but just drag when I pull the vac across my hard wood floors. Can you tell me...
It seems that the bearings of the wheel may have given, one reason why it will spin if in an upside down position but will drag if the right side up and with weight on it.
i do not see a locking mechanism on the wheels of you Vacuum, i believe having the wheels replaced will be the only solution to the concern.
10helpful
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
1helpful
I have a Harmony vacuum and need it only for bare floors. The attachment I have seems to be too rough on the floors. I just need a simple attachment with soft bristles for a bare floor that will fit this...
Take the lower portion of your wand to a vac shop and ask for a universal fit wide floor brush with NATURAL bristle. The soft bristle is much better quality and will clean deeper into grooves in your wood floor or and tiled area.
1helpful
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 • Vacuums
Protection light on my Electrolux 2100 vac is on
the carpet attachment pushes on a smsll switch to turn on the vac look for the pin
2helpful
2answers
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
2answers
Power head stops and starts
Sounds like there is definately something stuck inside it. You;ll need to dismantle the floor head carefully using a screwdriver. Make sure your machine is switched off though if it is a power head and not an air turbine turbo head. Once inside check the main roller brush as well as the side caps as these can become clogged. Also check the main dirt channel leading to the pipes of the vacuum.
Dont forget to rate, thanks.
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
Top Electrolux Vacuums Experts
Ekse
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
