Question about Texas Instruments TI-30XA Calculator
Decimals in the exponents for TI-30Xa
How do we do decimals in the exponents for TI-30Xa
k24674
  • Texas Instru... Master
  • 8,092 Answers
You have a key labeled [Y to the x], use it for all the powers or roots that do not have a dedicated key or key sequence. Let the key be [^]
Ex: 13.675 to the power 1.33 is entered as 13.675 [^] (1.33) [=].
The result is 32.41778634
Ex: (-64)[^](2/3) [=] gives 16 as result. The (-) is the change sign key
Ex: (2.87655)^(-6.778) is entered as 2.87655 [^] ( (-) 6.778 ) [=] 0.0007758
The (-) is the change sign (or the negative of), not the regular minus. When you have a negative exponent or a complicated exponent, it is safer to enclose the whole exponent inside parentheses.
Hope it helps.
Thank you for using FixYa
Posted on Nov 22, 2009
Testimonial: "This was really helpful. I was surprised by such a quick response. Thanks!"
1helpful
How do i enter a decimal exponent in TI-30XA calculator. for example 10^-8.85
Use the 10^x function in the top row of the keyboard.
Press 2nd [10^x] +/- 8 . 8 5 =
The +/- key is just to the right of the decimal point key.
If you're entering integer exponents, you can use the EE key just above the 7 key. For example, to enter 10^8, you can press 1 EE 8
1helpful
I need help on typing in exponents like (6.02*10^23) (8.65*10^4)
6 . 0 2 EE 2 3 * 8 . 6 5 EE 4 =
The EE (enter exponent) key is located just above the 7 key. If you want a negative exponent, make sure you use the +/- key located just to the right of the decimal point key instead of the - key.
I don't know how to type in negative exponents on my TI 30XIIS
The same way you type in a negative number. Make sure you use the (-) key just to the right of the decimal point key to enter a negative sign, not the - key you use for subtraction.
How can i enter a decimal exponent in ti -30xa
Use the EE key located just above the 7 key. For example, to enter 1.2 times ten to the 4th power, press 1 . 2 EE 4
Make sure you use the +()- key located to the right of the decimal point key to enter negative values.
How can I enter into my calculator exponents like (1.09 x 10-6)
Use the EE key just above the 7 key to enter exponents. Use the +/- key to the right of the decimal point to enter negative values. For 1.09 x 10-6, press
1 . 0 9 EE +/- 6
2helpful
How do i do negative powers of 10 on a texas ti-30x?
Use the EE key, just as for positive exponents. Just make sure you use the +- key (next to the decimal point key) to enter negative values, not the - key which is for subtraction.
2helpful
How would I calculate -log(6.2 x 10^-8) on my TI- 30XA
6 . 2 EE +- 8 LOG +- =
EE is the Enter Exponent key, just above the 7 key. +- is the Change Sign key, to the right of the decimal point key.
4helpful
How do I use a negative exponent when working working with natural exponential functions, on this calculator?
The same way you'd work with positive exponents. The only difference is that a negative exponent has a negative sign, entered with the (-) key just to the right of the decimal point.
The (-) is used to enter negative numbers, not just exponents. The - key is used to subract one value from another.
19helpful
How do I enter values in scientific notation
Use the EE (Enter Exponent) key just above the "7" key. For example, to enter 3.1x10^4, press 3 . 1 E 4.
For negative exponents, make sure to use the +<>- key just to the right of the decimal point instead of the - key.
I bought a TI-30XA months ago. I liked it so much
I do not know what to say. Since you seem to have a problem seeing the decimal mark, it may reduce the guessing if you use the scientific display format, which is always one digit, decimal mark, additional decimal digits, exponent. With this format the decimal mark is always at the second position (if there is no - sign) and at the third (if ther is a - sign). But if you are reluctant to use it there is no solution.
Hope it helps.
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
