Question about Radio Communications
Motorola T5725 walkey-talkey set,screen doesn't light up.
I have a motorola T5725 battery is good but the power doesn't transfer to the buttons.The red light is on but nothing works.
Posted by vin_damour on
Anonymous
Have motorola t5422 will not charge
Posted on Jan 28, 2010
2answers
Does anyone know the range of the motorola t5725 walkie talkies
from what i can find out its saying up to two miles range
2answers
Motorola T5725 - Earpiece with mic wont work
A few things you might check:
1) Be certain the radio is turned off when plugging in any audio device.
2) Be certain the device is plugged in all the way. You should feel it seat, or click into place.
3) Use a device designed for your model radio. Aftermarket accessories don't always have the functionality of the OEM device.
4) Be certain you have special features such as VOX turned off on your radio.
Hope one of these helps.
Best regards.
Want to know how to make old nextell / boost Mobil phone walkey talkey or chirrup work for free
Yes it is free, You should have a walkie-talkie ID number. Friends of your walkie talkie also have ID numbers install number to Your contacts scroll down on contact to (Options)D C. From there follow directions try to make a walkie talkie contact by pressing the side (PTT) or push to talk button , It a cinch. This may only work 4 sprint
Jan 22, 2013 • Cell Phones
2helpful
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
The talkabout t5500 and the t5725
Hello bella-9,
The T5500 is a 2 channel radio and the T5725 is a 14 channel radio. However, the radios should be compatible with each other on FRS channels 1-14 as long as both radios are using the same Quiet Talk code. If the Quiet Talk settings are different the radios will not be able to communicate with one another.
Assuming all settings are the same (as you say) and the units are within range of each other (typically less then a mile over clear, level terrain) they should work just fine.
Best Regards,
Ken
"Go Ahead. Use Us."
2answers
V3 got useless while ringtone transferring
you can take the phone and ahve the firmware reflash on the phone.
8helpful
4answers
Motorola T5725 won't work
I have T5720s - both have the same settings (channel 1), both are charged, but they won't communicate. They beep when you push the "talk" button, but you don't hear anything on the second radio.
Any ideas?
Thanks!
John
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
