On windows
start
all programs
look for the hp folder
2727nf folder
scan
if you do not see any of these options make sure the full software solution is installed.
Al
[email protected]
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action
49 and 79 Errors, Turn off then on
The product has experienced an internal embedded software error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
SOURCE: HP Laserjet M2727nf Mfp.
Turn off printer. Hold the CANCEL and > buttons, and turn on printer. When you see Permanent Storage Init release the two buttons. When the process completes you will see the ready message. This will reset ALL menu settings. If you screwed up the firmware update, you will have to replace the formatter. The NVRAM reset won't help you!!!
SOURCE: HP Laserjet M2727nf locks up /nothing works.
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
[email protected]
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
