Question about Dell Inkjet 720 Printer
I am no expert at printing. I have an important
I am no expert at printing. I have an important document that is typed in blue. My Printer 720 only shows it very faintly. Why?
    New Friend:
  • 70 Answers
You will need to increase the contrast of the image before printing. You may also want to change it to a greyscale image to improve quality.
Posted on Nov 23, 2009
Says the documents are in queue but they never print
You need to open your printer window and clear all your documents. Either go to start, settings, printers and faxes. Double click on your Dell 720, click on the file menu and click on cancel all documents. If necessary, after you do that, you can restart your computer. Then go back to start, settings, printers and faxes. Right click on your computer and click on properties. When the properties window opens, click on print a test page. If you cannot print a test page, then you need to check your printer install.
Let me know if you can print a test page after you go thru this process.
Brian
Mar 04, 2010 | Dell Inkjet 720 Printer
Can i print documents on a dell 720 photo printer
your computer does not see the printer or you did not select the printer from the print program try to reinstall the driver and then connect the printer to be able to see it
Nov 08, 2009 | Dell Inkjet 720 Printer
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
Got a new Del 720 printer. Using XP. Test page
go to printer properties and do a alignment and it will print like its made to do.
Jul 09, 2009 | Dell Inkjet 720 Printer
Prints in faint grey only, no real black
dear sir.
it's not a pritner problem. u need to chek word font's and font's colour setting but it's depand witch version u used and if every print are printed on faint grey colour yr refill cartige has a problem.. also do one thing go to pritnter setting do as grayscale. if u have any quary tell me..
May 04, 2009 | Canon PIXMA iP1800 Printer
Dell 720 prints faint
Have you gone into printer properties when printing the item then click advanced check what the settings are on. Your default settings may be to print draft quality which produces faint picture because it uses dramatically less ink. If you need further assistance let me know. Also a brand new printer of higher quality can be purchased for around 30$. So repair is definitely not a viable option if it is not a setting problem.
Thank you,
lee
Mar 01, 2009 | Dell Inkjet 720 Printer
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Faint blue horizontal lines
Try re-installing the printer driver it might be caused by a virus... if not then you need somebody to clean your printers head mechanism.. the blue cartridge might have messed an ink to its circuit.
Oct 27, 2007 | Epson Stylus Photo R200 InkJet Printer
Dell 720 Printer not printing envelopes.
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Jan 09, 2007 | Dell Inkjet 720 Printer
Dell Inkjet 720 Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
