Question about Kodak ESP 5 Printer
My Kodak Esp 5 want scan and I received a error message after trying to scan
Posted by cutelilmissb on
Anonymous
  • 262 Answers
Is this the error message you recieved 1-2000 or tricode code for example 235x892. please verify what error message you recieved. Now if your recieved an erro mesage numbers you may need to reinstall the software of your printer. please download the latest software and drivers of your printer at kodak.com/go/downloads
Posted on Nov 22, 2009
1 Related Answer
Jim Thompson
SOURCE: kodak esp 5 won't scan
The printer worked on everything but scan; when you pushed the scan button the screen would say "scanning" but nothing happened. I ran the install disk again and it gives you an option of fix problems and this worked for me. - Jim
Posted on Nov 30, 2011
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Jan 06, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
-Tried to scan and got error kodak lexicon executor has stopped working and when clicked cancel got error 2005. wireless esp7 ideas ?
The issue is with the new Home center 4.2 version.It is a very complicated issue and requires some difficult steps.I would request you to call Kodak @ 1800 421 6699 and try to ask for a supervisor straightaway.
Dec 18, 2009 | Kodak ESP 5 Printer
I can't download the software for an ESP 5250 onto vista...Help
did you tried to download the software on this website kodak.com/go/downloads. Now you didnt mention if you recieved a error message while downloading., Well in cased that you have a error message or a tricode error mesage you need to call Tech support of kodak toll free 1 800 421 6699 ext 05., Sometimes software has an issue in the .netframework of windows vista
Nov 14, 2009 | Kodak ESP 5 Printer
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
Kodak esp 5 won't scan
call kodak @ 1800 421 6699. This step involves advanced troubleshooting and is related with the scanner drivers of the Printers. Kodak telephone support will take care of the issue.
Sep 20, 2009 | Kodak ESP 5 Printer
When i press scan the display shows 'scanning' nothing happens - the printer works and is connected... kodak esp 5
connect ur printer with ur computer thru a usb cable and then try to scan a document from computer using home center software. u will be able to scan the document or picture.
Jul 28, 2009 | Kodak ESP 5 Printer
Error code: 1-2036
go to Kodak easyshare support:
http://www.kodak.com/global/en/service/products/ekn026079.jhtml?CID=go&idhbx=easyshareswsupport
In the box under Find Answers, type the complete error code (without spaces), then click Search. An error code should be like 12x413x1304x
Cheers
Jun 23, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 5 Printer Logo
261 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
