Question about DEI Python 1400XP Remote Start/Keyless Entry System
My python remote starter when starting in the morning only wil will runl. On my 2008 dicota truck will run less than a min. And shot itself off only in thr morn.
Posted by santo54 on
Daniel Boyes
    Sergeant:
  • 436 Answers
You need to reprogramme the tach input, the engine is running colder in a morning and will run higher for a few minutes, during the day the engine will be warm and idle quickly.
Posted on Nov 21, 2009
Remote starter comes only briefly and shuts off
Factory Remote Starter Quits After 5 Seconds - Diesel Place ...
www.dieselplace.com/.../340832-factory-remote-starter-quits-after-5-sec...
Nov 23, 2009 - 11 posts - ‎8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ... check engine light on wont shift
Oct 28, 2011
remote start
Oct 14, 2008
More results from www.dieselplace.com
Factory Remote Start Problem - 1999-2006 & 2007-2013 Chevrolet ...
www.gm-trucks.com/forums/topic/114985-factory-remote-start-problem/
Jun 12, 2010 - 10 posts - ‎8 authors
Factory Remote Start Problem - posted in 1999-2006 & 2007-2013 ... Sounds like you may have an intermittant code coming in and the dealer should be able to pull it out.2008 Sierra SLT ECSB Z71, Corsa Touring, and GMPP CAI .... the remote start button again the truck WILL shut off and the only way to ... Burning smell, white smoke - 2014 / 2015 / 2016 ...
Jan 11, 2014
2008 Silverado Electrical Issue
Aug 19, 2012
Making Factory Remote Start Run Longer
Dec 21, 2010
2000 Sierra, Starts Then Dies - Code 1631
Dec 4, 2008
More results from www.gm-trucks.com
Jan 05, 2016 | 2008 Chevrolet Silverado 2500HD
Remote Starter problem
Sounds like the immoblizer bypass is malfunctioning or, the pellet (resistor) in the ignition key itself is wearing down.
Aug 12, 2012 | 473P 3-Button TX Remote
Python 1400xp installed by circuit city on a 2004 chevy monte carlo. The car works fine but every now and then the car will not start with the remote or with the key, it takes 10- 30 mins to finally...
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
Sep 15, 2017 | DEI Python 1400XP Remote Start/Keyless...
Python 1600 XP Remote Starter my car starts at 1 pm daily automatically. How do I remove this timer on this remote starter
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
Dec 23, 2010 | 1600XP Security/Remote Start System
Python ce0890 FCC ID EZSDET474P RPN 473P 266 CODES. How do i reset this devise? The battery is good
While our Dodge ram truck sits - the horn starts blowing. We think it has to do with the remote and the security. We have the Python CE0890 remote starter - it is a few years old.
Dec 06, 2010 | 426P 460HP Security System - 426P
My car is starting on its own
your system was set by accident for cold weather start, which will start it every 2 or 3 hours and run for 2 or 3 min, good thing about this is it will only run do this for 1 day, or untill the car is started with the key
Feb 01, 2010 | DEI Python 1400XP Remote Start/Keyless...
Remote starter will not start vehicle
first thing i would try is locate the main box for auto start. usually it is under dash on the driver side when installed. then find the lage or hrness with the most wires going to it and unplug it/wait a few min. then plug it back in. sometimes the unit will go into a security mode. this will just reset it. if this doesn't work then let me know
Jan 06, 2009 | DEI Python 1400XP Remote Start/Keyless...
DEI Python 1400XP Remote Start/Keyless Entry System Logo
312 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
Derrick Schultz
Derrick Schultz
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
