Hi, I have DELL Inspiron 1525 laptop. It has some serious cooling issues, the fan goes crazy and the laptop switches itself off. It has an Intel core 2 duo T8100 processor, is it possible to replace just the fan or does the fan and processor come as a single unit.
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
The fan is a separate unit and is attached to the heat-sink assemble. Check to see is the heat-sink fins are not blocked with dust, if so remove the dust and the problem could go away. You may also provide extra cooling by placing the laptop on a fan assisted cooling pad, which blows air to the underside of the laptop.
