Question about GE 24 in. GSD2230Z Built-in Dishwasher
GE GSD2230 JUST RECENTLY I'VE BEEN HAVING TROUBLE GETTING IT TO START. I HAVE TO KEEP PLAYING WITH THE DIAL. IT'LL HUM BUT WON'T PULL ANY WATER. AFTER PLAYING WITH IT A WHILE IT'LL COME ON AND OPERATER CORRECTLY. I'VE NOTICED THAT WHEN IT STOPS, IT'S NOT STOPPING IN THE SPOT THAT IT USE TO. MY UNIT IS CLOSE TO FIVE YRS OLD.
    New Friend:
  • 31 Answers
Sounds like your control knob is broken or misaligned.....
take the knob off and check the shaft is not split...it should be "D"shaped and will only go on one way....if it has split you obviously have to purchase a new one.
Posted on Dec 17, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 170 Answers
SOURCE: GE Nautilus dishwasher wont run
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
Anonymous
  • 170 Answers
SOURCE: humming noise
I have seen this SOOOOO many times in my 35+ years in the appliance repair industry.......it is very typical....here you are this is an answer I provided someone with the exact problem not to long ago..............
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important) reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impeller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there's anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting dishwasher.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
This is an add on I thought about later...if you know someone who has or if you have or can get and electrical spray (cleaner/lubricant) it has to be nonconducting......spray for electric motors or coils...it will help prevent this to a degree and the motor will run better.
I hope this helps...Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 31, 2009
Chuck
  • 228 Answers
SOURCE: GE Dishwasher motor hums but doesn't engage.
These motors will stick sometimes during periods of not being used. With the power turned off to the the dishwasher, remove the front lower grille. There are usuallly 2 screws on each side of the panel. Looking under the D/W your will see the motor and pump assembly. If you feel around you should be able to feel the motor's cooling fan. Simply rock the fan back and forth and the motor/pump should become unstuck.
Posted on Jun 21, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: GE dishwasher GSD2230 won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Posted on May 19, 2011
DAB Jet 62 won't pump
U might've burned the start capacitor also. If u don't see one on the exterior,check inside the end bell (cap) of your motor. Do u hear the motor hum? If not there a likelyness u burned ur motor
May 26, 2017 | Plumbing
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 19, 2012 | GE Washing Machines
We have been given a computer that came with the phillips freevents mouse and keyboard, we have plugged in the usb and it flashes three times and does nothing we have tried to connect the mouse and the...
How to install wireless Keyboard and Mouse?Along with the development of the computer world, various brands of wireless keyboard and mice sets appear, you can purchase them from website or regular computer stores as well. Whatever your case may be, the directions for getting them ready for your computer are all basically the same. So, if you've bought a wireless set recently and you're having some trouble getting it to work, just follow these instructions and you'll be well on your way to wireless bliss!
First of all, wireless keyboards and mice aren't able to receive power from your computer like the wired ones do. Therefore, they need batteries to operate. And that's the first thing you need to do. Turn your keyboard over and you'll see a battery compartment. Take the cover off and insert the batteries according to the + - (plus, minus) compatibility. When you're done with the keyboard, you can go ahead and do the same thing for the mouse.
Once you've got the batteries in place, find a spot on your desk where you'd like to place both the keyboard and mouse. You won't have to move them around anymore, so make sure you find a place you'll be comfortable with. Now, while you're doing this, you'll also want to keep in mind where the wireless receiver will go. If you recall, a tip on that was in yesterday's newsletter.
The next thing you'll want to do is install the software that came along with your keyboard and mouse. Now, keep in mind that if you have Windows XP on your computer, you more than likely won't need to deal with the software at all. You can just plug the receiver into your computer and XP will automatically recognize the new hardware for you. On the other hand, if you're using an older version of Windows, you will need to install the software. To do so, just insert the disk into your CD ROM drive and follow along with the on-screen instructions. That's all you have to do!
The next step is connecting the wireless receiver to your computer, but again, if you have Windows XP, you've probably already done this. If not, it's likely that the wireless keyboard and mouse set you have works via a USB cable. So, all you have to do is find an open USB port on your computer and plug the receiver in. Once you plug it in, your computer will configure the keyboard and mouse so you can start to use them. You'll see a message that says something like "Your new hardware is now ready to use." (In XP, you'll get a pop up message that says "New Hardware Found"). Either way, that means you can now start using your new hardware!
Now that you've got everything set up, the next thing you'll want to do is test the keyboard and mouse, just to make sure everything's working properly. Go ahead and open some programs with your mouse and type some text in with your keyboard. Run through all the keys on your keyboard to make sure there are no problems with any of them and make sure all the buttons on your mouse work right.
Now, go on and enjoy your new wireless keyboard and mouse. Wireless really is the best way to go!
Apr 19, 2012 | Computers & Internet
I have a fzx 250 and i have trouble getting her started, I have just bought new spark [plugs for it but takes a bit to start and wont keep running and during the starting process i get a little pop from...
Sounds like lack of fuel to the engine. Has the bike been sitting for some time? You may want to pull the carburetor and give it a good cleaning payning particular attention to the jets. Don't use anything made of steel to clean your jets because you'll run the risk of enlarging and ruining them. I've had success using either wooden toothpicks (for large jets) or copper wire (small jets). Make sure you take your time and work very carefully when cleaning them; if you rush, you can end up with something broken off into a jet orifice and having to buy new ones.
Jun 25, 2011 | Yamaha FZX 250 Zeal Motorcycles
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
I have a GE DX4500EE1WW electric dryer. Over the weekend it stopped working. If you turn the start dial you can hear it hum so I know it's getting power but the drum won't turn. I've tried it on every...
MOST LIKELY A BAD MOTOR OR SOMETHING CAUGHT IN THE BLOWER WHEEL. UNPLUG UNIT, TAKE TOP PANEL OFF AND THEN FRONT PANEL. PULL THE DRUM AND BELT OUT AND LOOK INTO BLOWER HOUSING FOR RESTRICTION AND SEE IF YOU CAN TURN MOTOR BY HAND.
Oct 06, 2010 | GE Dryers
Jun 21, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
My front loading WCVH6260F will go through the wash cycle but will not rinse, spin or drain. It will stop showing 22 min left. I try to manually turn the dial to spin/drain or rinse. The machine will lock,...
Hi, I had the exact same problem. If you take out three phillips head screws at the bottom of the front bottom panel. Pull the panel down and off. Behind on the right is a white plastic circle. If you turn it counter clockwise it will unscrew and you can pull out and remove all sorts of debris from it. Be careful if the washer is full you get wet as it will drain through the opening. Since then I/ve had no problem and I found about a dollars worth of change in the filter for my trouble.
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
Can't get the dishwasher to start!
Sounds like the pump seal is stuck. Cut the power and look at the back of the motor. There will be a cooling fan in the end of the motor. take the fan and keep rotating it until the seals break loose.
Jun 28, 2008 | GE 24 in. GSD2000Z Built-in Dishwasher
Dishwashers Logo
71 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
