Tyan Thunder h1000E Motherboard Logo
Posted on Nov 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My h1000e takes long to shut down?what could be the cause of this and how do i solve this problem?
Rinoo Kumari
Level 2:
  • Expert 2,973 Answers
  • Posted on Nov 21, 2009
Rinoo Kumari
Expert
Level 2:
Answers
2973
Questions
0
Helped
642541
Points
712
Pepper, It seems that you installed something that is causing this problem. What happens is that when you shut Windows down, it has to close all programs running, whether in the foreground or in the background. Now, when all programs are shutting down properly then there is no problem. But when some one decides to resists the shutting down then Windows takes longer to abide by your instructions. You have to find out this/these program/s that you installed recently. Uninstall them if you can do without them. Alternatively close them manually before shutting down. What programs are these? That you alone can find out. Another reason. Does Windows seem to take longer while "Saving Your Settings"? If that happens, then there may be something wrong with Windows. Be prepared to reinstall Windows. Do not get alarmed, but just keep it at the back of your mind. Keep taking backups of your data regularly to be on the safe side.
My tablet randomly shuts off
Depending on what tablet you have, its possible that the power button is sticking causing it to shut down. Often with tablets holding the power down for 10 seconds will cause them to force shut them off. I would check that and if that does not work a factory reset may solve the problem.
1helpful
2answers
Why I cannot shut dow computer
try holding the power button until it shuts off (5 seconds or more) if it still not shutting off than pull the plug (it's frozen), reboot the computer, if it still does the same thing than have it checked by a good technician... it could be a defective main board, CPU/GPU, a virus, the powersupply or even the power button it self...
1helpful
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Shut down problem
the fan/heatsink asembly is most likely clogged .. causing the thermal controller to kick in a thermal overheating warning and shutting down the laptop
1helpful
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
1helpful
2001 pontiac grand am se occasionally shuts down when driving. check engine light is on!
Take the car to your local Auto Zone and ask them to scan the vehicle for trouble codes, they will scan the vehicle at no charge to you. Write the codes down and respond back to this post and we can begin problem solving.
The codes will help to narrow the system down that is causing the problem.
You might want to make sure the battery cables are clean and tight. If one of the cables has an intermittant connection problem, it will cause the car to shut down.
Good luck, let me know.
Regards,
W200i
the phone needs to be flash to correct this issue, take the phone to a mobile store to have this done.
My w200i phone keeps shutting down and reappear back like crazy!!!
the firmware needs to be flash on the phone to correct this issue....take the card and have it formatted.....
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Tascam 38
Usually the tension of the take-up reel keeps the shut-off arm taught and everything works. If the shut off arm falls down, the recorder stops. Is that what's happening?
Inadaquate (or NO) take-up tension can cause this; so can WARPED take up reels. Another possibility: if you play a lot of old tapes, the groove in the shut-off arm collects dirt and oxide, so the tape - as it goes through it - jams, and the take-up reel can not overcome the tension. The arm "falls down" and shuts off the machine. Also SOME tapes (which were "cut down" from 2"
tapes) are poorly ****, and will jam some machines.
This is what I do for a living, so if these suggestions don't work, give me more information, and I'll solve your problem.
Top Tyan Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
