Question about Olympus Camedia Stylus 300 Digital Camera
SOURCE: after charging the battery i put it in my camersa and it reading batttery empty
This happened to me before and its because i put the battery in the charger the wrong way up. Make sure you put it in so that the side with OLYMPUS in it in big letters is facing up!
Posted on Apr 25, 2009
SOURCE: blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Posted on Apr 29, 2009
SOURCE: pls help i have a problem with my olympus camera
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the position farthest from the contacts protects the card from writing. If the slide is already in the proper position, try sliding it fully the other way and then back again.
If that doesn't work, try a different card.
Posted on Feb 06, 2010
SOURCE: cracked/dead screen on Olympus 850SW
Hi, if you want you can replace the Screen in low coast. But i like to say its depend on you r country. But if you think in casual way then a new camera always higher price than a camera parts. So i suggest you visit a service center and tell them for replace your camera screen. It will cost approx 25 - 50 USD. Thanks & waiting for your feedback.
Posted on Mar 23, 2010
