Kenmore Elite Oasis 27052 Top Load Washer Logo
Question about Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
Posted by gregstyne on
Anonymous
  • 106 Answers
Bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Posted on Nov 21, 2009
MasterTech
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • Kenmore Expert
  • 86 Answers
The F51 error on the Cabrio, Oasis and Bravos are all the same error and can be quite a few issues, the link below show how to troubleshoot that error code.
Kenmore Elite Oasis Washer F51 Error Code Explained
Posted on May 02, 2017
2answers
10helpful
What does the error code F51 mean on the kenmore elite oasis he?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
My Kenmore TopLoading Oasis shreds my towels. What can I do to prevent this from happening?
Tighten the agitator. It has loosened up - allowing material to fit underneath.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Leaking and F51 error code on my Kemore Elite Oasis Washer
7helpful
4answers
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
10helpful
2answers
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
1helpful
2answers
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
1helpful
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
My kenmore elite oasis HE is not working and the code f51 shows up. What is this code?
2helpful
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
vince
Marvin
Marvin
