Is the full model number 596.76582600? The three-digit prefix indicates the actual manufacturer of the fridge with the Kenmore label. The manual covers a large number of Kenmore refrigerators. The water filter is only in select models. The 596.76582600 does not have a filter. The entire set of parts diagrams are available here: https://www.searspartsdirect.com/model/14cl4yks2t-000583/kenmore-elite-59676582600-bottom-mount-refrigerator-parts . The only filter listed is a refrigerant line filter for the coolant system.
I was going to explain a device called a "defrost timer", but I did a search on your fridge and found the following important information for you to check on FIRST!
I am pretty sure that two companies made the Trio for Sears and I will help you. At this point I believe you are having a defrost or damper control problem. Would you look around the frame or freezer drawer and see if there is a different number than p75523 because Sears uses that number for another reason than the true model number. You may find a Maytag number or an LG number on your model. Sears places numbers like this for example 323.26589 as a model number. I am ready when you are. Sea breeze
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator
to a new home and removed the bottom freezer door, but can not seem to
figure out exactly how to put it back on correctly.
It's too much for me to tell you myself. This is easier! Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf Thank you, Huuum, Please remember to leave a rating!
