Question about HP Deskjet 2360 InkJet Printer
SOURCE: error message top cover open
just make sure the cover is proper and there is nothing stuck inside.
Posted on Jan 28, 2010
When the printer is used often, and ink and dust accumulate inside, the detector switch will sometimes get stuck and won't be depressed by the cover correctly. Open the cover and look right next to the sticker. There is a small rectangular hole with the switch. Use a very thin tool like a small screwdriver or paperclip bent open to push the switch inside the hole to the back of the printer. Do NOT push it just down! You *must* move the switch away from you. Hold the switch in this position and close the cover. Carefully pull out your tool from the gap.
Posted on Apr 22, 2010
If you receive an "Open front cover" error message the solution is to open the cover and remove the paper and any remnants of the paper jam. If there is no obvious paper remnants jamming the printer and you continue to receive an error message I would suggest unplugging the printer from the power source.
After 5 - 10 minutes plug in to power source.
Turn on printer.
See if this has resolved error message. If not you will need to check more carefully for paper remnants that would be causing the printer to detect a jam.
Trust this is helpful. :)
Dec 08, 2010 | Konica Minolta PagePro 1390MF All-In-One...
Dec 03, 2010 | Dell 2135cn All-In-One Laser Printer
Oct 06, 2009 | HP Office Equipment & Supplies
Jun 09, 2009 | Konica Minolta DiALTA Di200 Copier
Feb 26, 2009 | Lexmark X3480 All-In-One Printer
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Aug 21, 2013 | HP Deskjet 2360 InkJet Printer
