Question about Casio Exilim Card EX-S600 Digital Camera
The camera turns on but the screen is blank. is there any way i can set it back to default with out being able to see the screen?
Posted by butterfly295 on
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
When camera turn , on screen -turn off and on again
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Setting Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Aug 14, 2011 | Sony DSC-S930 Digital Camera
When I switch the camera on the screen in blank
when you connect the camera with a cable to the television the screen is blank because that the default settings what you get in camera the television screen acts as a LCD of the camera , when u move your camera to click pictures you get the display on the television screen
Nov 21, 2010 | Canon PowerShot A75 Digital Camera
Canon digital camera led screen stopped working..did not drop or leave in sun..is just blank..canon powershot A590IS
I had this same problem. Once I got over about 1200 pictures, the screen just turned black, and the only setting that would work where I could see the lcd screen was the easy setting. I had read somewhere that this was due to the amount of pictures the camera had "counted", even if those pictures had been downloaded and erased from the camera. So I decided to reset the camera. Go to the tools list in the menu, scroll down to "reset all", and when it prompts if you want to "reset settings to default" click ok. This worked for me, and all of my settings - sunset, landscape, etc. - now work. Keep in mind that if you have configured any parameters in any of the settings (shutter speed, lighting, etc.) those will have to be reset.
Aug 31, 2009 | Cameras
Blank screen after turning on won't allow reset
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.
Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 04, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Blank screen when trying to take new pictures
CCD FAILURE!
Call canon for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
Service Advisory Link this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 26, 2009 | Canon PowerShot A590 IS Digital Camera
Blank LCD screen
Check your manual, page 141: Image Review. Should be set to ON (default is OFF).
Sep 01, 2008 | Nikon D200 Digital Camera with 18-200mm...
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Screen shows Kodak Logo when turned on then goes blank.
You've probably corrupted the firmware download. If the camera is still recognized by your PC then I'd try downloading the firmware again and try to load it again into the camera. I don't wish to upset you but corrupting the firmware can in some instances make the camera unusable. Your manual should tell you if there's a reset and how to do it. Don't forget the camera's firmware can also be upgraded by loading the update onto the memory card and running it from there. GOOD LUCK BMW
Jul 03, 2006 | Kodak EasyShare C330 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
Top Casio Cameras Experts
Steven Wander
Steven Wander
Greg Bernett
Greg Bernett
Are you a Casio Camera Expert? Answer questions, earn points and help others
