Sorry if this is an obvious question.. but did you plug the console back in firmly and are all the connections secure? If you can get it to power on again then here is a troubleshooting guide from Nintendo on syncing the wiimotes. http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
t is possible that your Wii remote has "lost" its sync. You can clear
all previous synced Wii remotes with your console and reconnect the
ones you are using. Power off the console and unplug the power cord for a
few seconds. Plug the power cord back in and turn the Wii back on. At
the "Health and Safety" screen, open the small door on the faceplate of
the console. Hold the red sync button for at least 15 seconds. All
previous syncs have been removed from your console at this point. This
process does not need to be repeated to re-sync each remote. Take
the first Wii remote you wish to sync and remove the door to the
battery compartment. Press and release the red sync button near the
batteries. Quickly press and release the red sync button on the console.
The lights on the remote will flash and then illuminate the light that
corresponds to that remote's position (1, 2, 3, or 4). Repeat this
process for each Wii remote in any desired order. fix it. God bless you
Turn off for a moment, try again, reconnect your controller.
Since its brand new, you can get it replaced if that doesn't work, dont waste your energy on it, just get another one, free replacement / warraty. Im sure.
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Your Wii controller has a power saver function built into to turn off the controller and save battery life. If it's not recognizing the controller, try rebooting the Wii. If that doesn't work then your Wii controller needs to b re-synced.
http://www.ehow.com/how_2144692_sync-wii-remote-controller.html
If it's not powering up at all then the batteries need to be replaced.
First unplug your Wii from power cord and wait 30 min.Then plug it
again and turn it on.Press and hold the red SYNC button for 15 seconds.
This will clear all synced Wii Remotes from the console.Then try to
sync it again.Push the red sync button on the console, then open the
batteries cover on your Wii Remote and push the red button there.Then sync and Wii Fit.If
this not help may be you have problem with bluethoot device on your Wii
and this need service.
Note: Make sure you have placed batteries in the Wii Remote.
Press the Power button on the Wii console to turn it on.
Remove
the battery cover on the back of the Wii Remote you wish to sync up,
and press the SYNC button just below the batteries. The Player LED will
blink.
Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
If that doesn't work, try putting fresh non-rechargable alkaline batteries in the remote and repeat the above procedure. The culprit may actually be your batteries.
Try this. It just worked for me. I actually didn't have to synch. After I unplugged the console and restarted, it worked.
Try these steps!
outlet.
Turn
With
batteries.
will blink.
4).
1, Turn off and unplug your wii console for a few minutes
2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
then try syncing your wii fit bored
