Have a 2005 Ford Mustang 6 cyl coupe. Have a Code Alarm keyfob that locks/unlocks doors, etc. Was working fine till today....new battery in it....when I push button on keyfob to unlock/lock doors...the keyfob light goes on..but doorlocks do not respond...help!!! :)
Bill
480-343-6919
SOURCE: alarm
When you use the manual lock switch on the vehicle you should see and hear the locks pick. When you use your remote you should also see the same results. If the drivers door does not respond with either you have a bad solenoid on the drivers door.
SOURCE: alarm goes off on own
ok this could be a easy fix i had the same problem in my 02 eddie bower explorer there is 2 switches in each door one tells the computer the door is open the other tells the computer to turn on the interior light so if you notice the door ajar light come on or your interior lights stay on for a prolonged period of time then this is for sure your problem this can also be your problem if the switches are just starting to go bad they will randomly pop in and out trust me this is what happened to me the switches are unfortunatly located inside the door now (i miss the door pin switch's) but they are still easy and very inexpensive to replace check your local auto parts store for the do not go to ford as they will charge you an arm and a leg :) good luck my friend
SOURCE: Alarm in a 2004 Ford Escape
Not a complete solution but something to try .Using the key lock and unlock the vehicle from the drivers door .Some models in UK have an arm switch on the lock barrel in the door which sticks.
HTH
SOURCE: I am having a problem How can I turn off the
disconnect the siren so you done have to listen to it. Is it a factory alarm or aftermarket?
