Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
Question about Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Is there any fixing with this problem of model 2740 that wont do anything rewind, play, fast forward etc just clicks clicks
Posted by lawjmm on
Javier Gonzalez
  • 207 Answers
Your unit has a broken cam gear you need to sen it to repair here are a place
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Posted on Dec 12, 2009
dick davis
  • 610 Answers
Call Wheeler Bus. Products, 877-245-3335. That is who we send Dictaphones to for repair. ask for Tom.
Posted on Nov 20, 2009
Model mp820 mp3 player. how do I fast forward?
Cheapo MP3 play with rewind and fast forward - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1687936
Digital Spy Jul 5, 2012 - 13 posts - ‎2 authors
Cheapo MP3 play with rewind and fast forward Tablets and e-Readers. ... can anyone recommend a cheap MP3 player that will allow you to fast forward, ... the yepp yp55 t had a wonderful "scroll through" function that took ...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
3helpful
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
84helpful
4answers
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
3helpful
4answers
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
2answers
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
