Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Bravia KDL40W2000 Remote and manual controls no longer work
I have a Sony Bravia KDL40W2000. Suddenly, the remote control doesn't work and the manual control buttons do not work properly e.g channel up button turns volume down, volume down button turns volume up. I've reset the TV, turned it of, changed batteries on remote, nut problem persists. Has anyone any ideas how to fix this? Regards, Steve
Posted by stevemonk836 on
  • stevemonk836 Nov 23, 2009
    Yes, that's the correct model number - displayed on the rear of the TV
  • electroman May 11, 2010
    Please recheck model number.
GreenHotrod Hotrod
    Habit-Forming:
    New Friend:
  • 105 Answers
Check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Posted on Oct 29, 2017
5 Related Answers
Anonymous
  • 320 Answers
SOURCE: sony bravia 46" remote control turns on the TV but no other buttons work
First, change the batteries on the remote with e new set of batteries. Check to see if you can bring up the menu using the buttons on the TV itself. Let me know what happens
Posted on Oct 18, 2008
Anonymous
  • 41 Answers
SOURCE: My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
Posted on Apr 21, 2009
Anonymous
SOURCE: Sony Bravia TV Remote controls the iHome clock radio
I am as well, does anyone know how to change or fix it-- it is driving me insane!
Posted on Dec 22, 2009
Chi Chu
  • 8457 Answers
SOURCE: My sony bravia tv remote control has sticky
Take out the batteries there a screw behind it take that screw out.Must take something sharp like a nife.Pride it out all around the remote for lases.Clean the remote with some rubbing alcahol.
Posted on Mar 17, 2010
Anonymous
  • 86 Answers
SOURCE: tv doesn't respond to remote controller
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
Posted on May 18, 2010
Why will the volume button on my Sony Bravia remote not do anything?
Return it, it is a faulty remote if just days old and not functioning.
Mar 31, 2016 | Sony BRAVIA Televison & Video
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Cannot jump to any channel
Try again using English Grammar and proper words please.
Jun 18, 2017 | Sony BRAVIA KLV-40BX400 MULTISYSTEM LCD TV...
Sony bravia 40cx520 jump button
download your owner manual and read very well
the specification and proceed with your requirements
www.fitness.manualsonline.com
God bless you
Sep 24, 2012 | Sony RM-Y915 Remote Control
My Sony Bravia is stuck on channel 2 and won't respond with the remote or the top of the set channel changer.
I have the same problem. I have the Sony Bravia KDL-40S4100. I can't get it off channel 2. It won't work with the remote, and it won't work on buttons on the top of the console either. The power button on the remote is still able to turn the TV on and off, but aside from that, everything else is frozen.
Dec 15, 2010 | Sony KDL-32M3000 32 in. LCD Television
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
296 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
