Question about Philips Televison & Video
Ineed to know how to interconnect our tv, vcr, dvd and top set box, Can you help? Philips DVP3120/05, Philips VR720 Philips 282 tv with built in dvd and Bush free view top box.
Anonymous
    New Friend:
Problem solved : incorrect connection of scat leads Solved by roof top digal aerial Digi top box and on to VCR. and then on to TV.
Scart from VCR to TV
Scart from VCR to DVD
Scart from Digi Top Box to TV.
Everything now functions correctly
Equipment connected:
Philips VCR: 720/07
Philips TV : 28PW6515/05
Philips DVD: DVP3120
Bush top box
Posted on Nov 22, 2009
Combo VCR/DVD player has no cable connection on back> How do I hook it up, through adigital box, to an older TV with one set of white, yellow and red connections?
What outputs are available on the digital box? If you have composite out (AV), then you connect the yellow (video), red and white (audio) to the VCR composite IN on the DVD player. Then connect the composite out from the DVD player to the TV. You will need an extra RCA composite cable. If you need one, they can be found in most stores. (try an online shop that specializes in cables to avoid an outrageous price). The VCR In is to the Right of the DVD/VCR Out.
If the incoming cable is only available with a coax connection, you will need a set top box and a coax splitter. Connect the incoming coax to the input of the splitter. Then connect one coax cable to the TV antenna/cable in. Connect the other to the set top box and then connect the composite output of the set top box to the VCR composite IN.
The manual and the quick start guide are available as PDFs here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=DVP3345VB/F7 . For diagrams of the connection to a cable or other set top box see the FAQs on the right hand side of the page.
If your cable box has some other output, you will need an appropriate converter to go from component to composite video for example.
I hope this helps.
Apr 22, 2011 | Philips DVP3345VB/F7 DVD Player/VCR
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Getting rid of subtitles...for dummies
Actually, just found out that it works (sort of) by clicking thr set-up button in the remote for the DVD player. Not sure how and why, but it seems to have sorted the problem
Sep 12, 2009 | Philips Magnavox 27MS343S 27" TV
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Universal remote code for Magnavox tv's
Try this web page
http://www.directutor.com/content/philips-sru210327-universal-remote-control-codes-tv-vcr-set-top-box#codefinder
Sep 21, 2017 | Philips Magnavox Learning Universal Remote
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
552 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
