Question about Proficient S12 Subwoofer
I have the same problem as described by Fufanuer. I have no power to S12 Subwoofer as it keeps blewing fuses. As I replace the fuse 4a 250V with new one it blew right away. Can anyone help? Hal
Anonymous
    New Friend:
I too am looking for the solution, I'm hoping I have the wrong power cord which is sending too much power to the sub, my next attempt will be to just up the AMP on the fuse b.c hey it's broken anyway
Posted on Nov 30, 2009
Garage opener fuse keeps blowing
The motor start capacitor is most likely shorted. The motor could be bound up or the door is stuck. PS. Wasting fuses after the first one blew is pointless.
Nov 20, 2015 | Building Materials
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
1501 sub will not power up. i opened, inpected and replaced power fuse 250v 6.3 amps replaced with same fuse and it blew as well immediately. what to do and how. I have some technical experience.
Isolate and look for possible shorted components.
Isolate the main power transformer from the board, and see if the
fuse still blow.
If it doesnt , then the rectifier and capacitors to the regulators.
But don't forget to check for possible shorted transistor
Sep 23, 2011 | Mackie SWA1501 Subwoofer
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
PS8 Subwoofer started buzzing non-stop
with nothing connected and the sub turned on....Most subs buzz when the circuitry starts to fatigue. The last time I heard this ..the repair ended up being one of the two fat capacitors inside the sub. I have a means of testing this,,you may not. I am a repair shop with a bit of experience in component level board repair.
May 06, 2010 | Proficient S12 Subwoofer
Brookstone Wafer-thin CD with MP3 player circuit failure...why?
sure, ur power amp section is completely shorted. meaning it is totally fried. get it repaired. it was a stupid idea to jump the fuse. u cud fry the whole thing!!! i sincerely hope it is only the power amp. if it is more than that u have only urself to blame. remember looks can be deceptive.
Apr 13, 2010 | Brookstone Wafer-Thin CD System with MP3...
AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Jun 01, 2008 | Acoustic Research AR1 Speaker
Subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Nov 02, 2007 | Audio Players & Recorders
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Proficient S12 Subwoofer Logo
400 people viewed this question
Top Proficient Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Proficient Audio Player and Recorder Expert? Answer questions, earn points and help others
