Question about Necchi Sewing Machines
NECCHI, model 4795. Thread bunches up at bobbin.
NECCHI, model 4795. Thread bunches up at bobbin. Whats' the fix?
Posted by strahles on
  • Anonymous Mar 25, 2014
    Cannot thread the bobbin, what do I do?
Michael Thorpe
    President:
  • 2,702 Answers
It sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
Anonymous
    New Friend:
Cover of the reverse button is missing on my necchi model 4795.
purchased used- what is the approximate age of this machine?
Posted on Feb 05, 2010
PRINTABLE MANUEL FOR NECCHI MODEL 4795
Unfortunately very few sewing machine companies provide free online manuals. However, you can download one for a fee at this website:
Necchi Model 4795 Sewing Machine Instruction Manual
Nov 30, 2017 | Necchi Sewing Machines
I need manuel for Necchi sewing machine model 4795
Hi
... the first link seems to be charging about $15 for the manual ... here it is
http://www.sewingpartsonline.com/instruction-manual-necchi-4795.aspx
However, this second link seems to be free ...
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Necchi/Necchi_4795_instruction_manual.htm
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
May 04, 2017 | Necchi Sewing Machines
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
When attempting to sew the bottom of fabric "thread starts bunching up after about 3 stitches....Help....what is wrong
you might try checking your needle to see if it's bent-roll on flat surface to see if it roll correctly
or blunt or damaged
some sewing machines bunch up like that when the thread come off the thread take up lever
also check the top tension
check for lint or loose thread in the bobbin area
check to make sure the bobbin is wound correctly
Sep 25, 2010 | Necchi 4575 Mechanical Sewing Machine
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
695 people viewed this question
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
