make sure you are not using too much detergent. no more than 2 teaspoons. try running the unit with no detergent a few times. if problem still persists then check the door seal or remove the door panel and make sure the overflow tray running along the base of the door where the hinges are is not blocked with food. also check the door is closing enough to seal,the door latch may have moved. check the tightness of the screws
yeah is probably junk on the door seal, Thank you
