Computers & Internet Logo
Anonymous Posted on Nov 20, 2009
Dell Latitude 630 docking station USB ports no longer work
I have a Dell Latitude 630 laptop and a docking station that is about 8 months old. All of a sudden, none of the 3 USB ports in the docking station will work...One day they worked, then the next day they didn't. I haven't dropped it or anything, it's been sitting in the same spot for almost a year. Does anyone know what is going on? Is there something that needs to be reset on the laptop? This is my work laptop; I just purchased a 620 laptop, and when it's in the docking station, the same thing happens. Help!
  • Anonymous Nov 25, 2009
    That worked! Amazing how something that simple made the 4 USB ports immediately available. Thank You! (BTW, I purchased this docking station on Amazon for $14.99 back in Feb. '09. Check them out B4 you pay top dollar!)
John Sparozich
Level 2:
Sergeant:
Champion:
  • Expert 357 Answers
  • Posted on Nov 20, 2009
John Sparozich
Expert
Level 2:
Sergeant:
Champion:
Answers
357
Questions
Helped
111506
Points
625
Try removing the laptop, unlug the power to the dock and wait a few minutes, then connect the power now put your laptop back on the dock.
I hope this helps.
Have a good day and good luck.
Windows 7 driver
You can download drivers from the manufacturer's website. Have you tried windows update?
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
I connect docking station and enabled docking hardware profile, after that when i boot no display Model Dell Latitude D 630
I believe your docking station profile is corrupted.....I suggest you to remove the existing one and allow system to recreate a new one by rebooting the computer.
1. Open System in Control Panel.
2. On the Hardware tab, click Hardware Profiles.
3. Under Available hardware profiles, Select Profile 1 (Current), and then click Delete.
Reboot the computer and test. It should work.
If that fails then you may want to try with different docking station.
2helpful
2answers
My Dell Latitude XP laptop got knocked to the floor. It fell on the side where usb port was connected to printer. Usb port pins are now bent and port is unusable. Dell said I have to replace...
No, it's not the only way, if you have an unused PCMCIA port in your notebook. The width of the PCMCIA port is about the height of a credit-card, and the height of that port is about the thickness of a few credit-cards.
Purchase a PCMCIA adapter that has two or three USB ports.
Insert the PCMCIA adapter into the slot,
and connect your USB device to one of the USB ports.
Will not print when docked
I would recommend that you undock the laptop, go into the Printers and Faxes console, and delete the printer. Then, dock the laptop, connect the USB cable to the dock and then re-install the printer through the dock. The USB ports on the laptop are assigned different hardware values than the PCI interface of the dock, and if the laptop is trying to print to a local USB port, it may not find the printer if it's connected through a PCI interface like the dock. That'd be my next move.
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
5helpful
Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Grand Canyon Tech
Grand Canyon Tech
