SOURCE: my ilo tv wont work wright
I do have the same problem on my ILO 26HD It worked fine for about a year and sudenly it got freezed, can anyone please find what it is?? Thanks!!
SOURCE: My Ilo flat screen tv just stopped working
The ILO is less than then a year old and the sound will not ajust nor will the remote work. I tried the buttons on the side and they will not work either. What to do?
SOURCE: sound but no picture
check with a flashlight against the screen for picture, if present backlight inverter has failed.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
SOURCE: 42 inch ilo tv black picture sound only
If the fuse burned out the the tv would not turn on at all. When the tv is on is the back light still on? If its not its probably the back light that needs changing. If its on then its one of the circuit boards.
