Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
How do I change the belt on Eureka Altima 12 v
Posted by jpc0816 on
Vac Belts
  • 701 Answers
Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Posted on Nov 20, 2009
1 Related Answer
Anonymous
  • 34 Answers
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Posted on Jun 14, 2009
How to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dec 31, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Replace a broken belt
Nov 15, 2009 | Vacuums
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
What type of belt fits best with my eureka altima 12 amp
The replacement from Eureka will work for certain, but any brand of belt that indicates it can be used on that vacuum will work.
Let me know if you have any additional questions.
Feb 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Just need to know how to change the belt on my vacuum cleaner
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
1,083 people viewed this question
Top Eureka Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Mike
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
