My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state after initial warm up. It was a refurbish unit. Even though it looks good and makes good coffee.
try to make pregroun coffee ,but without beans,just press pre groud button -if water comes out then yuor coffee beans are too fine- turn to hight number the grinder
Hi your brew unit is blocked. Open the service door and remove the brew unit and wash and rinse under water. Hot is better. The spout on the back side of the brew unit canbe unscrewed and cleaned. This is where most blockages are, Dazza REPAIRER
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Check the line where the water goes to the brew unit(be careful), disconnect and try to brew coffee, if water exits then the blockage is elsewhere, check the line where it goes into the white plastic valve behind brew unit, if water flows then check the brew unit make sure it is not blocked at the screen.
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
