Eljer 111-2875-00 White Sherwin One-Piece Elongated Toilet 111-2875 Logo
Posted on Nov 20, 2009
IS THIS AN ADA HEIGHT TOILET? - Eljer 111-2875-00 White Sherwin One-Piece Elongated Toilet 111-2875
Level 1:
Scholar:
New Friend:
  • Contributor 35 Answers
  • Posted on Nov 20, 2009
36069
Contributor
Level 1:
Scholar:
New Friend:
Answers
35
Questions
0
Helped
16204
Points
55
ANSI 117.1a 2003, which is determined to be "SAFE HARBOR" for accessible design, requires that an accessible toilet be 17" to 19" in height. Most regular toilets are 14" to 16" in height. Therefore, about 2 to 4" is the difference between ADA and regular toilets. I also checked the spec. sheet for this toilet on Eljer website. According to the spec. sheet, this toilet is an ADA toilet.
How to tighten the seat on toilet
Put your hand around the back of the seat and you will feel the nuts. Tighten them by simply turning them.
My toilet keeps filling on it's own
Replace flapper. Use American Standard flapper for your unit.
Water level in bowl low
Turn knob on top of float ball to increase ball height which will increase water column. Up to 1" of overflow tube.
Toilet occasionally running
replace flapper with American Standard flapper.
1helpful
What is the purpose of the small hole at the back of the toilet bowl?
f you are asking about the small hole on the back out side of the bowl it is there to hang the toilet when they put on the porcelain coats.
1helpful
Are there concerns with toilets which have a lower water tank height to fill the toilet bowl when efficient flushing is needed?
I would say that there are no concerns that are not a concern with most of the new toilets of today, regardless of tank size it should always be designed to hold more than 1.6 gallons of water. The key is to find a toilet with the largest flush flapper as you can allowing all of the water to be used quickly and effectively. hope this helps.
The toilet fills up high but drains very slowly
sounds like your toilet probably isn't vented properly through the roof or might have too far of a run to where it may connect into your main vent stack
4helpful
Installed cadet 3 and every twenty minutes it will run for about three seconds and i know it isn't supposed to do that
EITHER THE FLAPPER IS NOT PROPERLY ADJUSTED OR YOU WILL NEED A NEW FLAPPER. WATER IS SLOWLY LEAKING BETWEEN FLAPPER AND SEAT. AS WATER LEVEL DROPS ,TOILET WILL RUN TO BRING WATER LEVEL BACK TO PROPER HEIGHT.
How to disolve sillicone caulking from a toilet tank lid.
Here ya go:
http://www.dap.com/docs/tech/00017116001.pdf
Eric
Top Eljer Home Experts
john h
Gene Lawson
Sean Wright
Sean Wright
Are you an Eljer Home Expert? Answer questions, earn points and help others
