HP Color LaserJet 2600n Printer Logo
Posted on Nov 20, 2009
Dull colors on half the page
When I print a page with color across the entire width of the page, the colors on the left hand side are lighter than than the same colors on the right side. The toner cartridge is new.
TimmyQMS
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Nov 28, 2009
TimmyQMS
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
14126
Points
74
I would replace the transfer belt see if that makes a diffrence hope this helps
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Pages printed with dark horizontal lines the entire length of the page with a repeating (lighter) images.
I have seen bad laser scanners cause this...
A black line across the page from left to right, of various widths, at various intervals, all the way down the page.
First, though, I would reseat the toner cartridge. If the problem disappears, you are in luck!
Try another Toner Cartridge to see if the problem disappears.
It could also be a bad control board.
Good Luck.
3helpful
Dell Color Laser 1320c printer. The left side of page prints lighter than rest of page - color faded or lighter
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
2helpful
2answers
Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
1helpful
Line down one side of page.
One of the ink nossels are blocked you can use benzien or hot water to unblock them
2helpful
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
1helpful
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Left hand side prints faintly
inside the toner unit, there is a stirring device to broadcast toner over full width of drum. I will guess this is the culprit, the stirring device is not turning. Try this test: remove the toner cartridge and shake it rapidly back and forth. Then try a print, any change?
k24674
Grand Canyon Tech
Grand Canyon Tech
