1999 Chrysler Concorde Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio stopped working followed by power locks
While driving, the radio turned off and stopped working altogether, the digital clock too. after a few minutes i noticed the power locks no longer worked either.
Anonymous
Level 3:
President:
  • Master 676 Answers
  • Posted on Nov 18, 2009
Anonymous
Master
Level 3:
President:
Answers
676
Questions
Helped
287478
Points
2168
Locating 3 amp fuse to radio which is secondary fuse after main fuse at the fuse block under dash. Followed wiring diagram which indicates fuse should be near or inside radio enclosure.
Question edited for clarity, 'fuse', unless you light it 'fuze'.Question moved to sub category.
If the radio has an inline fuse, it will be within 82 of the plug at the rear. They are built into the harness. Unlikely because there are three fuses covering audio.
https://fuse-box.info/isuzu/isuzu-trooper-1992-2002-fuses-and-relays
C11 10 (AUDIO[ACC]) MIRROR Audio, Door mirror, Door mirror control SW, Door mirror folding SW, Digital clock, Speaker C12 20 CIGARETTE Cigarette lighter C13 10 ANTI THEFT Anti-theft controller C14 15 STOP A/T CONT Stoplight SW (w/o cruise control), Brake SW (w/cruise control), Rear wheel anti-lock brake controller, Stoplight, Transmission control module, Electronic brake control module, Trailer harness connector, Cruise control unit, A/T shift lock control unit, Lockup off relay C15 20 AUDIO[BJ] Horn, Horn relay, Horn SW, Hazard warning light SW, Flasher unit, Anti-theft horn, Hazard warning light, Audio C15 20 TELEPHONE Telephone C16 10 CLOCK[B] ROOM Digital clock, Audio, Dome light, Map light, Luggage room light, Courtesy light, Door SW (Front, rear, tail gate), Antenna, Anti-theft controller, Key remind SW, Seat belt, Key & light remind buzzer
1helpful
99 Durango- after battery change chg that dome light, radio and tripometer stopped working.
didnjt i see this question a few days ago ,i think they blew a fuse connecting up a secondary power source by the sound of it
Car shutting off while driving
The battery light would come on because the engine has stopped running and the alternator is not charging the battery. The steering would get difficult to turn because the engine would not be turning the power steering pump. So those things would be expected.
It sounds like you have a relay that is failing, or you are loosing power from the key switch.
Radio and clock wont turn on in 1992 toyota pickup
inline fuse may be the problem. pull the radio out and check for power
Just bought a used truck it is a 1995 full size chevrolet it has a theft lock radio but does not work,the radio will not show any display not loc r lock there is a button u push it will show u the time...
If the clock will display for a few seconds that means it,(the clock) has power, and perhaps the entire unit. However, if the anti-theft is engaged, a dealer will be in your future. It will take them about a minute to un-lock the radio, or they will know if the radio no longer works.
3helpful
2answers
Suddenly my radio and clock stop working, it was working for few day after it stopped working but again stopped working.
You could have a short some where in the wiring. If its an aftermarket radio see if you can pull it out and check to be sure all wires are properly done.
If its a stock radio then check the fuse panel!
3helpful
What fuse is for the clock in my 95 ford taurus
Clock Memory Fuse 8 and Digital Clock Fuse 6 .
A/C Compressor Clutch Fuse 17
A/C Heater Control Switch Fuse 17
A/C-Heater Mode Switch Fuse 9
Air Bag Diagnostic Monitor Fuse 7
Air Bags Fuse 5
Amplifier Fuse 11
Autolamp Dual Coil Relay Fuse 4
Backup Lamps Fuse 5
Blower Motor Speed Controller Fuse 17
Clock Memory Fuse 8
Courtesy Lamps Fuses 6 & 8
Daytime Running Lamps Fuses 5 & 10
Digital Instrument Cluster Fuses 5 & 16
EATC Blend Door Actuator [1] Fuse 17
EATC Blower Motor [1] Fuse 9
EATC Control Module [1] Fuses 5 & 16
Exterior Lamps Fuses 4 & 15
Flash-to-Pass Switch Fuse 10
Hazard Lamps Fuse 1
Heated Oxygen Sensor Fuse 5
Illuminated Entry Fuse 5
Illuminated Entry Module Fuse 8
Instrument Illumination Fuse 13
Keyless Entry Fuses 5 & 8
LCD Dimming Relay Fuse 6
Lamps On Warning Fuse 4
Lamp Out Warning Fuses 6 & 15
Liftgate Window Defrost Fuse 6
Liftgate Window Washer Fuse 6
Liftgate Window Wiper Fuse 6
Light Sensor/Amplifier Fuse 18
Low Oil Level Relay Fuse 18
Main Light Switch Fuse 6
Manual Lever Position Sensor Fuses 5 & 10
Mobile Telephone Transceiver Fuse 11
Police Accessory Relay Fuse 6
Power Antenna Fuse 11
Power Mirrors Fuse 8
Power Windows Fuse 6
Radio Fuse 11
Radio Memory Fuse 8
Rear Window Defrost Fuse 5
Redundant Radio Control Fuse 11
Shift Lock Actuator Fuse 5
Speed Control Amplifier Fuse 6
Speed Control Deactivator Switch Fuse 1
Stop Lamps Fuse 1
Transmission Control Switch Fuse 18
Turn Lamps Fuse 1
Turn Signals Fuse 5
Variable Assist Power Steering Module Fuse 5
Warning Chime Fuse 6
Warning Chime Module Fuse 18
Warning Indicators Fuse 18
Windshield Wiper Control Module Fuse 2
Windshield Wiper Motor Fuse 2.
this will help.thanks.
4helpful
The digital clock stopped working even after installing a new one
This is a very common problem with many mid 1990 - 2000 model vehicles. I offer a repair solution that is far cheaper than buying a new clock. Check out www.autoclockrepair.com. I also have the removal instructions there, check it out!
1helpful
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
1helpful
1997 Toyota 4 whl. Drive/6 cylinder..clock & radio light problem?
The clock unit is just defective and needs replaced. It is pretty common on these 3rd gen (96-02 Runners) -they are not cheap so many folks have just given up on them. T4R.org is a good place to look for one or a local junk yard if you need to replace it. While you have the dash apart for the clock then ...
Your radio issue is likely in the unit itself-and replacing the radio head unit with a more modern unit would likely be around the same cost as any fix of the old unit. Since many car stereo outlets install for free your only limitation is how much you choose to spend or the features needed. I seriously doubt Toyota can fix your light in the old stereo for any less than a new radio itself....but of course call the dealership and ask to be sure before you go spending big money....
Ron In Denver
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
