2001 kawasaki ZX-6R Ninja Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
00 kawasaki ninja zx6r my bike don have no power, no lights or horn, nothin is comin on whats wrong , i check battery and fuses plus starter relay everythin is ok i just dont have no signs of power, thanks
tim blarr
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 13, 2015
tim blarr
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
960
Points
Did u ever figure this out
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Nov 18, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3088657
Points
19604
Hi and welcome to FixYa,
I understand that you have checked the:
  • battery - that it is fully charged and that the cables & terminals / connectors are clean and tight;
  • fuses - including the 30 Amp main fuse;
  • starter relay - there is +12 on the white wire.
Should the above hold true, then the only remaining components to suspect / check would be the always on +12 connectors and/or the ignition switch.
Good luck and thank you for asking FixYa.
On a 1996 ninja zx 600 have power to key switch no horn no signals start button does not work either all fuses good whats wrong
Try looking at the main fuse (30amp) on the starter solenoid. Make sure handlebar run switch is to on position - we all do it! and also check battery connections are tight - especially the negative lead.
1999 Kawasaki ZX-9R Ninja will not turn over
Test the battery, bike batteries can and do just go open and dead all of a sudden, have been stranded more than once, filled with gas and then no start nothing, no lights nothing.
6helpful
2answers
Wiring diagram 2001 zx6r
Try this manual, it should cover all your needs. Are you sure you have the correct rating fuse in the box, the manual will solve the problem any way. Good luck:
http://vitek.vellum.cz/manualy/Kawasaki%20Ninja%20ZX-6R%2000-02%20Service%20manual.pdf
I want to chang the horn in my kawasiki ninja zx6r
the horn is only held on by 1 bolt,undo this and remove the 2 wires then just reverse these steps to refit
1helpful
Charging problem/no start 95 ninja zx6r
If lights dim when trying to start,Battery is to weak(may have 12 volts but not enough amps)
Bike dieing when removing power from jumper says the lighting coil on the stator plate is bad and this could also have killed the voltage regulator,Which would kill the battery by over charging it.
Hesitation and carbon smell could be from a non firing cylinder.
So,Take the battery and have it load tested (free at most auto part stores)
Check for power from the lighting coil on the stator
Replace the voltage regulator.
Please rate this fixya
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
