Question about Canon PIXMA MP530 All-In-One InkJet Printer
My computer can not find my new wireless printer. the printer said it is connencted to the the right SSID and the printer software is downloaded but they cant find each other. Also when i look in to my connection setttings on the printer it has a different ip address and subnet mask? how counld this be. My computer is connnected
Posted by marshallk_22 on
Andrew Henderson
    Sergeant:
  • Canon Expert
  • 394 Answers
Check the Lan/Wlan settings on the printer. Set to DHCP for address and reboot the printer. This should ensure the machine is getting it's IP address from your router. Recheck the IP address and subnet mask are in the same range as your computer and router and try a test print. If that does not work - manually set an address in the printer with a terminal value of 50 eg 192.168.0.50. Try that. If still no good, reset the printer IP to DHCP automatic and reboot the entire system. Please note if you are using Apple/Mac portable computers - your IP address range may change every time you boot in a different location.
Posted on Nov 16, 2017
5 Related Answers
carpediemweb
  • 54 Answers
SOURCE: Konica Minolta Bizhub c252 network problem
firqst: DHCP disabled
copier IP adress should be 192.168.x.y
IP Pc must be 192.168.x .z (169.254.xx.xxx is a bad address!! = No-IP address !!)
see my recommendation for the scan on a previous post (http://www.fixya.com/support/t1395654-konica_c252_scanning_address_book_job)
Posted on Jan 06, 2009
Anonymous
  • 10 Answers
SOURCE: Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip 192.168.1.20
and the copier ip 192.168.1.30
Posted on May 02, 2009
Joed911
JDTec
  • 4338 Answers
SOURCE: setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 06, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: Hi
Are you possitive that your iR3300 has printer kit installed. That series of Canon copier comes with NIC installed, but the print DIMM and network firmware is an additional option that needs to be installed. If I remember correctly, there is a way to display the firmware levels...you would see iR3300n (network).
Posted on Nov 08, 2009
shawn38
Shawn
  • 200 Answers
SOURCE: canon IR 1023if; trying to network with buffalo
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Shawn
Posted on Jan 29, 2011
How do I connect my laptop (wireless) to my HP printer envy 5660 (wireless)?
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
  • If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
  • Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
  • Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
  • Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
  • If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
  • Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
  • Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
  • Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
  • Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
  • To complete the software installation, follow the on-screen instructions.
  • You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
  • If the printer is not turned on, press the Power button to turn it on.
  • On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
  • On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
  • Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
  • Turn on your HP printer and eject any USB cable if connected to the printer.
  • Go to our website and navigate to the download page where you have to download the printer software manually.
  • Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
  • Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
Jul 26, 2018 | HP Office Equipment & Supplies
How to connect to wifi on pro 950
I found this on google. Hope this helps:
Q: I've tried to install the product's software for a wireless connection, but cannot complete the installation. What should I do? A: Do the following: Important: You'll need to know your network name (SSID) and network password before you can set up your product. If you don't know them, contact the manufacturer of your router or the person who set up your network.
If you know your security settings, continue with these steps:
  1. Reset the product's network settings. Press the home_button.gif home button, if necessary. Select Setup. Scroll down and select Restore Default Settings. Select Wi-Fi/Network Settings. You see a confirmation screen. Select Yes to reset the selected settings. (Select No if you want to cancel the operation.)
  2. Turn your router off and back on. Important: If your router is connected to other devices, you may need to re-establish the connection for the other devices on the network.
  3. Close all applications (including any screen savers, virus protectors, and firewall software) before you install the software.
  4. Uninstall the printer software (Windows only), then reinstall the printer software.
If the steps above for a wireless connection do not help, check the additional troubleshooting tips below, then try steps 1 through 4 again.
  • If you're setting up the printer for the first time, make sure you have the correct SSID (wireless network name) and if security is enabled, the wireless network password (WEP key or WPA passphrase). This information is stored in your network's router and you may be able to access it by logging onto the router from your computer and checking its setup screens. If you are unable to access the information, contact the person who set up your network or the manufacturer of your router or access point for details. (Epson will not be able to provide this information to you.) You'll need to know the SSID and wireless network password before you set up the printer.
    Note: The SSID and security key or passphrase are case sensitive. Be sure to correctly note uppercase, lowercase, and numeric/special letters.
  • If your wireless router or access point is set to not broadcast its Network name (SSID), you'll need to enter the SSID manually in the printer's setup software. If your wireless router or access point has wireless security enabled, you'll also need to know what kind of security it is using. Epson will not be able to provide this information to you. If you don't know this information, you'll need to contact the manufacturer of your router or the person who set up your network.
  • Make sure the product is within range of the wireless router or wireless access point.
  • Avoid placing the printer near a microwave oven, 2.4 GHz cordless phone, or large metal objects such as a filing cabinet.
  • Check to see if access restrictions, such as MAC address filtering, are set on the router or access point. If access restrictions are set, add your product's MAC address to your router's address list. If you're unsure on how to do this, contact the manufacturer of your router for instructions. To obtain your product's MAC address, print a network status sheet.
  • Disable any settings (such as AP Isolation, Client Isolation, or Privacy Separator) on your wireless router or access point that would prevent wireless devices from communicating with each other.
  • Make sure your system meets the requirements.
  • Make sure all applications (including any screen savers, virus protectors, and firewall software) are closed.
  • Make sure you have administrative rights or software installation privileges to your computer.
Nov 11, 2014 | Office Equipment & Supplies
How can i connenct my computer to wireless network
need more info, what happen when you try to connect? maybe the router configuration is not leting you connecth
Mar 28, 2014 | HP Compaq nx6310 Notebook
What is a ssid code for printer setup
The SSID is the name given to a wireless network when a network is created. You can choose to broadcast or not broadcast the SSID of the network. If you hidden the SSID, then your wireless network will not be "visible" to other computers looking to join the wireless network, meaning that computers will only be able to join your network if they know the SSID beforehand.The SSID would be found on the router. This is for a printer that has wireless printing capabilities.On your computer click on the wireless network indicator in the status bar and you can see the SSID of the router the system is currently connected to.
Jan 16, 2011 | Epson Office Equipment & Supplies
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a...
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
How do I know what my SSID is for my NetGear router Can I hard wire a printer and also send jobs by wireless to same printer? Do I have to download the software in order to print wireless from a different...
Go into the router configure to view the wireless settings, it contains the SSID and encryption etc.
Open IE browser and enter the Netgear URL configuration IP address (http://192.168.0.1)
A network printer must have a built-in print server or be attached to a print server device on the network then all the computers on the network can access this printer.
For a run of the mill printer to work as a network printer it needs to be attached to a computer which is on your network and the printer needs to be setup as a shared printer. This printer and computer must always be switched on for the other computers on the network to access and print to this printer. This method does not require any additional software.
Nov 18, 2009 | NetGear WGR614 Wireless Router
Have BROTHER PRINTER that will accept wireless, It needs ssid to operate. i am using vista 64 bit. can u help me please
The SSID is the name of your wireless router assuming you have one. That series of printer isn't designed for PC to Printer direct wireless but rather to have your PC print over the network connection through the router to the printer.
If you do have a wireless router and just don't know the SSID, go to your wireless computer/laptops networking screen in control panel and view the available wireless networks. The one you're connected to is yours. The name displayed in that window is the SSID you need to enter into the printer.
Note: you will also require the routers password if it is a secure router.
Hope this helps,
Chris
Jul 09, 2009 | Dell Computers & Internet
Hp 2175 printer all in one problem wirless printing
Hi Kate,
Please click on the following link to download the software for you operating system. Since you have not mentioned the operating system please select thr right one while downloading. You can get the operating system by right clicking on my computer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90809&lc=en&cc=us&dlc=en〈=en&cc=us
Thank U
Jan 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
SSID - computer cannot find the printer
You need the new driver, download from Kodak.
Vitally
Jan 11, 2009 | Kodak EasyShare EX1011 Digital Picture...
DO NOT REMEMBER SSID NAME GIVEN TO ROUTER WRT54GS---LOST PRINTED COPY OF SET-UP. HOW CAN I REPRINT OR JUST FIND OUT INFO
You can see the SSID name from one of your wireless computer that is already connected to the wireless network. Just point your name over the wireless little computer icon down at bottom right hand by the time. It will say there "Wireless Network Connection, Connected to "name of the network". That "name of the network" is the wireless signal name like "Linksys" or whatever name you gave to your network when you setup the router. That's the SSID name as well. Wireless Network Name = SSID.
Aug 27, 2008 | Linksys Wireless-G WRT54G Router
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
408 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
