2003 Cadillac CTS Logo
Posted on Nov 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote will not lock or unlock doors on 2003 Cadillac CTS
David Shaub
Level 3:
President:
  • Master 2,994 Answers
  • Posted on Nov 16, 2009
David Shaub
Master
Level 3:
President:
Answers
2994
Questions
Helped
1153455
Points
8370
It's time to replace the battery in the remote. They use a regular button cell, available at most battery racks.
Anonymous
Level 2:
  • Expert 134 Answers
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
47031
Points
387
Try replacing to battery in the key fob
My 2003 Cadillac CTS starts then immediately dies. Causes please.
Question edited for clarity.
Question moved to model category.
By disconnecting the battery, you also disconnected all the set up of the security and engine immobilizer coding.
https://www.google.com/search?q=2003+cadillac+cts+security+system+reset
How do i perform the 2003 Cadillac CTS anti theft reset?
Vehicle History https://www.vehiclehistory.com > questions > how-do-...
To reset the anti-theft system in your 2003 cadillac cts depress the key fob's panic button for five seconds before pressing the lock button twice standing ...
2 answers · Top answer: To reset the alarm on the 2003 Cadillac CTS You have two options. You can pop the hood and disconnect the positive battery cable, then leave it off for ... People also ask
How do I get my Cadillac out of anti-theft mode?"
Look for a button that allows you to slide the physical key out of the fob. Step 2: Turn the vehicle key to unlock the car door without releasing it. Hold the key for 30 seconds in this position. This will signal to your car's system that you have the right key, and will enable you to bypass your car's alarm system.
2008 Cadillac CTS rear passenger door wont unlock with the remote. all other doors and trunk work. must manually lock and unlock door that door. anyone know what the issue is, and is that something I...
see the diagram attached. YOu must test the mechanism for lube, or damage parts, loose wires or connector corroded, switch dirty Lube WITH wd-40, test the motor or solenoid
God bless you
2helpful
2answers
Remote control won't lock/unlock doors, but will open the trunk. What;s wrong?
There is a fuse box under the right rear seat cushion behind the driver. In that box is a 10 amp mini fuse marked "TRUNK DR RELEASE". That is the fuse that powers your remote receiver. If that fuse is good, the receiver may have failed. To remove the seat cushion, pull the front of the cushion up and then forward.
3helpful
2003 cts cadillac need unlock code for radio cd player stoped working bought one from salvage yard it locked
call cadillac or maybe even gm dealer and give them vin number
gm dealer ask for martin @ 281-929-3250....houston tx
15helpful
2answers
I need to program a key fob for a 2004 Cadillac CTS. I just purchased the car used. it came with ONE key and nothing els. I have recently purchased a keyless entree remote suitable for the car and was...
Remote Key FOB Information
Transmitter Programming
 1. Close all the vehicle doors.
   2. Insert the ignition key into the ignition lock cylinder.
   3. Press and hold the door unlock switch.
   4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
   5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
   6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
   7. Repeat the previous step to program up to 4 transmitters.
   8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
   9. Operate the transmitter functions in order to verify correct system operatio
1helpful
No sound from radio / now car totally dead
Its you antenna module above your headliner. It controlls your remote for keyless entry as well as your am/fm reception via an amplifier. GM part number is 12233252 for updated and revised version around $100 bucks online.
2answers
CTS rear back side window - how to replace
Tire Size P225/55R-16
**** / Florida
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
