Question about Garden
Not working Craftsman Leaf Blower
We have a Craftsman leaf blower that is only a couple yrs. old. My husband thinks there is a problem with the carbauerator as cannot get it started. Want to find someone to repair it for him. Does Sears do repair work there.
Posted by tirvin2 on
Roger Geer
  • 78 Answers
No Sears does NO repair work themselves.They send it to a repair facility. Tell your husband to take off the air filter cover,drip NOW I MEAN DRIPing a few drops of 2 cycle fuel into the carburetor ,close the choke and pull the rope.This may take a couple of times of doing this before it fires . If it does not fire and he knows for sure there is spark. Then the blower is problably toast. THESE blowers are made cheap and only last a few hrs. of run time,Unfortunately.
That machine is made my POULAN I have scrapped out at least a dozen this season because they are worn out and with no hrs on them to speak of.
Sorry
Posted on Nov 16, 2009
  • Roger Geer Nov 16, 2009
    Sorry
I have. Troy bilt snowblower, 3 yrs old and it just stopped moving forward or backward. The blower works and when I start the blower, the propulsion works a little bit then stops. I used yesterdAy and...
check the drive belt from engine to the transmission, sounds loose or even off. If belt and tension are ok check pulley for sheered key or loose coupling
Feb 09, 2013 | Garden
Hard starting my leaf blower
Heat the carburetor with a hair dryer for a few minutes,OUTSIDE.
Nov 14, 2012 | Craftsman 25cc Gas Blower
My craftsman 32cc leaf blower won't stay running
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
I have an old Craftsman leaf blower and it won't
most likley a fuel problem, start by replacing the fuel lines, fuel filter and diaphragm and gasket set in the carb. Non use is the worst thing for any 2 chcle small engine. The modern gasoline that contains ethanol, spoils in about 3 weeks and damages these parts.
Oct 31, 2009 | Craftsman Garden
How can I download an operator's manual for an Echo power blower, Model PB-1000?
http://www.managemyhome.com/mmh/home?intcmp=MMHxG_HomexHome_Header
try this web site, they have a lot of manuals to download. found a manual for an old craftsman leaf blower there.
goodluck,
packrat101
Apr 19, 2009 | ECHO, Inc. PB-251C Handheld Blower
Craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
