Question about Planar PDP-42BK 42 in. Plasma HDTV
Perfect pic on top half of screen bottom half blank
Posted by njshorerealt on
Duke
    President:
  • 1,284 Answers
Most likely the lower y-buffer board which is mounted to the left of the panel in the back of the TV is bad. I believe you can get LG equivalents for these boards. There should be part numbers on the board itself..
Posted on Nov 11, 2009
When printing my emails I only get only half the message, top part and the bottom half is blank.
Depending on which email service you are using, I.E. Hotmail, you may only be getting a screen shot of the email. In other words it will only show exactly what your seeing on your screen if you simply right click and print. Hotmail has a little ACTIONS with a downward pointing arrow on the right side of your screen. Click that and select print and it will print the actual message instead of a screen shot of the message. I have to assume other email servers use similar techniques to print the actual emails instead of just screen shots. Hope this helps.
Sep 17, 2014 | Dell Computers & Internet
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Vizio half of screen is solid color bars. Top half works great.
You have either the circuit board that drives that half of the screen(one for top and another for the bottom) or you have a bad display panel.
May 25, 2012 | Vizio 32-inch Sv320xvt Full 1080p 120hz...
Laptop display only displaying the top half of the screen
Test it with an external monitor if it works fine then you will need to replace your LCD screen.
May 04, 2010 | Dell Latitude D600 Notebook
Blank top screen
This is one of those things that I regret to say but the only way to repair this would be to order a new Flex cable. the flex cable is a small flat ribbon cable that connects the bottom half with the top half. It would be easer to replace the entire thing instead of just the ribbon cable
May 20, 2009 | Nintendo DS Console
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
Bottom half of screen goes blank
Take it to a repair facility, don't be a cheaps ***.
Jul 27, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Top half of screen
Blue STK392-040 Convergence IC bad = replace both with
first quality parts = NO generics,they don't hold up. I USE
PANASONIC with great success................T.
Dec 02, 2007 | Akai PT4298HD Rear Projection Television
Planar PDP-42BK 42 in. Plasma HDTV Logo
83 people viewed this question
Top Planar Televison & Video Experts
Lee Hodgson
Lee Hodgson
JonSnell Electronic
JonSnell Electronic
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
