Question about Westinghouse Computers & Internet
When I turn on my monitor it flashes on for a second then the screen goes black, why is it doing this?
  • 3,741 Answers
Its the problem of back light supporting inverter board.if its a LCD monitor then only its inverter board problem.but if its a normal monitor not lcd one then its the problem of power supply board.
you can get the inverter as well as power supply board at www.radioshack.com
or at local computer part store in your area.
the cost of power supply board is near to $65 and cost of inverter board is $35.
thanks.
Posted on Nov 11, 2009
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My screen turns black when i turn it on it flashed the creen for
first should do is first try to trim the monitor or meaning mounting a LCD or external CRT monitor to see to fix laptop are behind
Jul 22, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Lg l1920 lcd monitor's screen flashes when turned on
Could be an inverter problem, if it powers on for a brief second and then flashes off then the inverter is at fault. Check for any Capacitors which have a yellowish substance at the top, they looks like round blue or black cans and if they look like they are buldging then they will need replacing.
hope this helps =]
Feb 11, 2009 | LG L1920P 19" LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
562 people viewed this question
Top Westinghouse Computers & Internet Experts
ByRuss
Level 1 Expert
Ekse
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
