RCA L46WD22 Television Logo
Anonymous Posted on Nov 11, 2009
RCA LCD l46wd22 failed firmware upgrade
Rca tv failed firmware upgrade and now doesn't come on, is there anyway to force load firmware?
Anonymous
Level 3:
President:
  • Master 1,284 Answers
  • Posted on Nov 21, 2009
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498382
Points
3271
You probably want to contact RCA technical support. As far as I know though there is no force that you can do and most likely you will have to replace the main board. Anyway contact RCA technical support. Was there a particular reason you were updating the software?
Why does my RCA smart tv keep turning off and on by itself. I didn't have this problem until I upgraded my network in order to get my apps to load.
Sounds like corrupted firmware. A firmware update will make it OK. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Firmware upgrade procedure to many TVs and other devices are given with illustrations.
3answers
TTEDI_L12.8.0o_dev.upg
Hi I have the same problem with this firmware, could you fix it?. thanks mail: [email protected]
RCA 46
If a LCD either a problem related to the back lights if used or a problem on the digital control (main board) and in either case not a do it yourself fix.
How do I get the upgrade to the firmware to my RCA LCD TV?
If there is an upgrade/s for it you would have to contact RCA (Thompson) to see where to get and what is involved in installing.
My l46wd22 LCD screen is cracked. Help me please!! And i hve a message on my screen saying "unusable signal". Can I buy a lcd screen & help with the message?
a type of LCD screen used for some portable computers; there is a separate circuit for each pixel.
Broke to pieces has traded one.
Need software upgrade
http://support.ttetech.com/en-us/softwareupgrade.html
On this website if you look halfway down you should see L46WD22 firmware instructions and download. Read and follow the instructions to the letter as this has the potential to further damage your unit.
Hope that helps!
RCA L46WD22 LCD tv (3 year-old unit)...No picture, tried unplugging for a few hours to ''re-set'' the computer...nothing, tried to view a DVD, nothing, just a black screen with the ''unusable signal''...
The back lights inverter is working because you can see the "Unusable Signal' on the screen, if the inverter is dead, yoo will see nothing on the screen at all.
If the T-CON (LCD controller) is dead, you will see just gray glowing screen with no pictures or text.
You may have problem with video processor in the main logic board (tuner, audio, source selector).
Parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L46WD22+&stock=all&limit=100
This is going to be difficult repair since you do have a way to try out the replacement board to be sure that is the problem. RCA service person has that advantage of parts in stock to try out.
I estimate the board from Jimmy to be about $150, from RCA will be twice as much, plus labor.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
RCA L42WD22yx6 with no picture , audio is fine.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD Inverter backlight board for the replacement.
Failed Firmware Update
You have learned a painful lesson the hard way - never do an upgrade or firmware upgrade unless it is absolutely necessary to do so. Often, the procedure fails and you are left with a nice paper weight. Bet you that you did not save the original firmware (or were not given the chance to do so). If you cannot get it from manufacturer you are SOL. But you have learned, haven't you? Good luck with RCA.
3answers
RCA L46WD22 firmware
have you gotten any resolution on this yet?
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
