PocketDish won't boot up. When I press the on button I can hear the hard drive spin for a second, and the green light comes on, so long as I continue to hold the on button, but then nothing more happens. Also, when charging the battery, the battery charge light does not come on, yet apparently, the batter does charge, at least enough to support the activities that I described above, which is the same regardless of whether the unit it plugged in, or is on battery power.
SOURCE: ARCHOS 404.. new.. won't turn on or charge
Leave it to charge for 2 hours just in case there isn't enough power for it to boot up properly until it has an initial charge.
SOURCE: 605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
SOURCE: my archos 7 wont charge the red light comes on but
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
SOURCE: Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
