Jenn-Air JMC7000 Microwave Oven Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a built-in stove/microwave model JMC7000ADB. When I turn the microwave on, I get a loud buzzing sound in addition to the normal microwave sound. Sounds like a motor starter not starting...or something like that. Most likely problem?
Anonymous
Level 3:
  • Jenn-Air Master 43,501 Answers
  • Posted on Aug 07, 2010
Anonymous
Jenn-Air Master
Level 3:
Answers
43501
Questions
0
Helped
10841792
Points
101584
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Kenmore microwave Model No. 721.62463201 runs but does not heat and has a terrificately loud buzz. All lights displays are normal
Hello there:
There's no heat, but it buzzes loudly When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. I recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
And if you have your warranty for this you can use it to ok
Hope this helps best regards mike
11helpful
2answers
Whirlpool microwave makes loud buzzing noise
When your microwave oven won't cook your food, and, you hear a loud buzzing sound, it’s normally caused by a faulty (a) diode (b) high-voltage capacitor (b) magnetron.
The diode would be the most likely culprit of the three components. It’s also by far the cheapest!
2helpful
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
10helpful
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
1helpful
Kenmore microwave making loud buzzing sound.
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
1helpful
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
