Question about Kohler 12 kW Emergency Power System - 12RES-L
When I try to start my generator the code oc comes
When I try to start my kohler 12 res generator the code oc comes up. It will not turn over at all. I checked the battery and made sure it was putting out 12 volts. Checked the starter for any loose wires and did not find any. Any suggestions?
Posted by arthurcrossj on
Anonymous
    New Friend:
  • 37 Answers
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
Posted on Nov 18, 2009
Kohler 12.5 res gen. Battery is good. Get OC code. If I reset auto switch by clicking off, then clicking run, then clicking auto it will start. Any thoughts on this issue?
OC is Over Crank which generally means it cranked and cranked and failed to start. Turning the switch off and on again is the way to clear the fault. How long is it taking to start whilst cranking? It should start within 8 seconds
Sep 11, 2013 | Kohler Electrical Supplies
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
Kohler 12K RES where are links for the installation /setup of the controller? thanks
The 12RESL has no user setup. That's part of lower cost on the DC 2200 controller versus an ADC 2100 or ADC-RES controller that came with the 12 / 17 / 18 RES models. Here is a link for the ADC 2100 Operation / Installtion manual though. http://www.scribd.com/doc/60318571/Kohler-8-5-12RES-Install
Sep 14, 2011 | Kohler 12 kW Emergency Power System -...
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Oct 11, 2010 | Kohler 12 kW Emergency Power System -...
Have Kohler 12RES. Gives a CC1 code thenan OC code. Have checked out the starter, it's OK, have cleaned all ground cables and connections and had the battery tested it's OK. Where do I go next?
check your load wires there probaly reversed. I had the same problem friday. The week before the electrican wired it. did the same cc1 then oc. had a generator company come out it was the wireing. my load and netural were reversed.
Sep 07, 2010 | Kohler 12 kW Emergency Power System -...
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
I have a Kohler 12RESM1 propane generator with oc/uu code
U need to make sure that the relay driving ur auto start stay closed all thru the crank cycle.
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Apr 20, 2009 | Electrical Supplies
Kohler 12 kW Emergency Power System - 12RES-L Logo
1,069 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
Tim Venetis
Marvin
Marvin
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
