Check your owner's manual. Then try the other button? This is a new car, though. Try disconnecting the negative battery terminal for about 15-minutes to reset 'all'.
On my 2003 ST T30 X-Trail the radio is called SY702, this is printed to the right hand side of the number 6 button.
Turn the ignition to ACC, turning the radio on.
Press and hold both 'AUDIO' and 'AS' simultaneously for 3 seconds. Clock display will start flashing.
Release 'AUDIO' and 'AS'
'1' button advances the hours.
'2' button advances the minutes.
When you're finished setting the clock, press 'AUDIO' to lock the time in. Ant :)
yaris has only one button for setting clock.......... long press this button the hours will start blinking then set the hours by pressing the same button.......... when finished setting hours wait for some seconds then the minutes will start blinking set the minutes by pressing the same button and after setting leave it best of luck
To reset the hour: Push the "MODE" button until the hour display appears and blinks. Then push the "RESET/ADJ" button. To reset the minutes: Push the "MODE" button until the minute display appears and blinks. Then push the "RESET/ADJ" button. After resetting the clock, push the "MODE" button until the display returns to normal calendar mode.
Press and hold the CLOCK button until you hear a beep. Change the hours by pressing the H (Preset 4) button until the numbers advance to the desired time. Change the minutes by press the M (Preset 5) button until the numbers advance to the desired time. When you are finished, press the CLOCK button. Vehicles without CD Player Adjust the hours by pressing and holding the CLOCK button, then pressing the H (Preset 4) button. Adjust the minutes by pressing and holding the CLOCK button, then pressing the M (Preset 5) button You can quickly set the time to the nearest hour. If the displayed time is before the half hour, press and hold the CLOCK button until you hear a beep, then press the R (Preset 6) button to set the clock back to the previous hour. If the displayed time is after the half hour, the clock sets forward to the beginning of the next hour. For example: 1:06 will reset to 1:00 or 1:52 will reset to 2:00 Hope this gets you there.
To reset the
message displays, turn the ignition switch on. Press and hold the
odometer reset button “A” located below the speedometer. Turn off
the ignition while holding the button. “OEL” will display on the
indicator. Press and hold the lower digital clock reset button or
the analog clock reset button “B” until five dashes appear in the
display. If needed, next
press the odometer reset button until IN 01 is displayed and then
press the clock reset button until five dashes appear. If needed,
next press the odometer reset button until IN 02 is displayed and
then press the clock reset button until five dashes appear. To exit reset
mode, turn ignition switch on and when IN 01 appears, turn ignition
off.
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear.To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON. 2. Press and hold odometer reset button below speedometer. 3. Switch ignition OFF and release odometer reset button. OEL will now display. 4. Press and hold the lower digital clock set button or the analog clock set button until five dashes (-----) appear in display. 5. If necessary, pree odometer reset button to proceed to the IN 01 display (15,000 mile maintenence) and reset using the clock button. 6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence) display. 7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
- turn the tape deck/radio off.
- then press 'mode' on the display - use the 'arrow keys' to set the time - up and down - change figure - left and right - select minutes/hours - press 'trip' to return back to normal
