Question about Hitachi P42A202 42 in. Plasma TV
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
Posted by colin20569 on
Duke
    President:
  • 1,284 Answers
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Posted on Nov 11, 2009
Just got a hitachi 42hdt50m model plasma and cant figure out how to hook up cable. we have no cords that came with it. what do we need
You're going to need a coax cable about the length of the distance from your TV to your cable source, either the wall outlet or your digital cable box provided by your cable provider.
For good measure, get yourself an HDMI cable if you have certain digital cable boxes, DVD or Blu-Ray players. check out cablestogo.com for inexpensive cables. Don't get suckered into the expensive cable.
Good luck.
Apr 13, 2011 | Hitachi 42PD3000 42 in. Plasma Television
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
Blue ray disc player is working fine, but the tv is not showing any channels. We are just installing our new tv. What did we do wrong?
I just bought a samsung BD-P4600 and I tried to connect with a Philips Plasma TV. What channel do I need to put it on for it to show?
Sep 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Does a 2002 Hitachi 61' 61swx10b have a pixel count ?
you have to tell your blu ray player to only output 1080i via component cables. Do this in the blu ray players setup menu.
Feb 23, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No power to my Hitachi 42hdm12
Hi, If even trying the TV in another known good outlet, it still doesn't work, do a hard/full reset - turned off via master power or unplug for a couple of hours. If all else fails, maybe you should seek the services of a qualified professional since this involves opening the unit, circuitry diagnosing and board/component repair/replacement. Hope this be of some help/idea.Post back how things are or should you need further information. Good luck and kind regards.
Aug 26, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Hitachi P42A202 42 in. Plasma TV Logo
298 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
