Uniden Cordless Phone Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no dial tones on our two uniden 5.8GHz cordless phones. New batteries were installed.
Anonymous
Level 2:
Scholar:
  • Expert 79 Answers
  • Posted on Nov 11, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
79
Questions
0
Helped
24511
Points
243
Make sure the phone and the phone base is turned on. Check the phone cables at the back of the phone base where you charge your cordless phone. It should be properly connected to the phone jack on the wall and at the back of the phone base. Try unplugging and replugging it back in. If that fails, try changing the phone cable. If still there's nothing, try to connect another phone on the phone line. If you get a dial tone, it means you have a problem with the wireless phone set, if not, contact your phone company.
NO CONNECT Signal in cordless phone
I have a Uniden cordless phone. It was working fine until I put in a new battery. Now I don't get a dial tone. What is wrong
1helpful
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
4helpful
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
3answers
3answers
No dial tone
try pulling the batteries out for 24 hours and then putting them back in. It should reset all the software and it should sync back up.
2answers
Hello, While I cannot locate that model in any Uniden database (you might want to find the literature), It sounds as if the handset may be communicating with its base, but you have lost the dial tone. Did any storms pass through recently? Here is what you do. Go to your base and push the locator button on your base station to call the handset via the page/locator function. If it rings the handset and you can answer it okay then you know your handset is working well and communicating with your base (the radio portion is working correctly). If it does not ring your handset then your Uniden is definately bad (radio wise). But, I am going to guess that it is okay but you still cannot communicate with the outside world and dial out to get dial tone or get an incoming call. Okay, so we have a dial tone problem. The next step is to see if dial tone is getting to your base. So you will need to take another good telephone, preferably a handy "line powered" telephone (no batteries or ac adapter needed) you can use in a power failure emergency. Take that good phone and plug it into the phone cord you unplug from your Uniden base. If you get dial tone, then your uniden does need repair. If it does not get dial tone, then you have a bad cord, jack or something in your phone wiring. If thats the case, change cords, look for corrosion, dirt or bent pins in the jack on the wall. My guess is that your Uniden has gone bad, likely from a slight surge on the phone line. If you do need your Uniden repaired you can contact Uniden they are at http://www.uniden.com/repair/service.cfm , however I don't believe they offer repair, but offer to sell you a replacement. Or you can go to www.cordlessrepair.com where you can get your Uniden Cordless unit repaired, not exchanged. Good Luck, CG
1helpful
CORDLESS PHONE - NO DIAL TONE
Plug out the power from the main charger and then plug in again. It needs to reset after they have gone dead. Immediately you can lift one of them off the charger and you will hear your dial tone.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
